I am very new to lights. i like the 801 802 pencil beam for my hunting (hogs).
I bought one of these for $13 US just to test because it was so cheap. Didnt need it but I bought anyway.
hs 801 802 has a pencil beam
light below has a larger beam (about 2 to 3 times 801 802) and guys i run with like it more when looking thru scope. I want pencil beam cause wont set off hogs as quick and penetrates brush and woods better.
Super Tactics CREE LED 400 Lm Flashlight Torch Lamp New
Again, I am new to lights and do not know all the terminology and stuff. Just wanted to drop a suggestion for you to look at. Hope I dont add to confusion.
The Super Tactics is a good thrower, especially for the price. Nice beam too, not extremely tight.
Be aware though that it's driven far above the manufacturer's specs for that emitter and will therefore probably not take kindly to long runs (more than a few minutes) in High mode.
I have one of those and am curious what will happen if I use it in high mode for a long time. I left it on high for about 15 minutes tonight and it worked just fine.
I have the Fandyfire STL-V6. I haven't measured the exact time, but I have had it on high mode for about ten minutes without it dropping to medium. I am using the xtar 18700 s. Will do some tests later and post it here.
Interesting. Definitely a clone, but much shinier finish than the M8. I wonder why no tube extension for the 2x18650 option of the original? Price is hard to beat.
The Solarforce anodizing is type III, which Jacob's most certainly isn't.
With an XR-E emitter, 2x18650 is much less of a requirement, due to lower current compared to the XM-L draw on the original. The regulation could probably be better with 2x18650, but the driver would likely cost more.
To get down to 1/5th the price, some corners just have to be cut.
After reading Old4570s review, I recently imported a batch of Maxtoch SN6X-2s from China - which various hunting friends have bought. This torch sold as Fandyfire STL-V6/Skyray/Maxtoch SN6x-2. Have to say the Maxtoch original products are very well made, and they are stunning performers in the field.
Did some testing on a hunting trip and they are easily the best hunting lights have seen. They combine very good distance, good spill for scanning fields, and are strong enough to be used as an off-the-truck spotlight.
Did some google measuring and they lit up a house at 270 yds quite well, and had no trouble picking up buildings at 350 yards. Could just detect light influence on hills at 540 yards. Main usable light for picking up small game like bunnies is out to 170 yards - in right conditions and with 9x scope. Thumping power output out past 100.
This light is an absolute beauty and friends have twisted my arm to bring in another batch. Sorry boys but these are coming to New Zealand.
Old4570 gave this light 5 stars and so would I. Huge light output and an ideal hunting light. Go for it.
Yeah that light… I received couple of weeks ago, and after running for 10 minutes, boom lights out ! I sent it to E1320 for a 5 mode 7135 driver swap with a .001 lumen firefly mode. He suggested : Hi Manny, I can stick one of the new XREs that pulls 2.8 amps and it will out throw anything short of Deft HO and I can do the custom 5 mode if you want with the firefly low. I said do it ! I’m waiting for the light … Should be ready and shipped next week … >)
