While none of HJK’s comments say “buy **Fire, they don’t exactly say ”don’t buy” either.
From HJK’s 2012 battery tests:
Trustfire 3000mAh 18650
The performance matches a quality 2600mAh battery, but I cannot say anything about how it will age. For a cheap battery it is a good battery.
Trustfire 900mAh 14500
The battery is good for a cheap battery, but the voltage under load is considerable lower than the best batteries.
UltraFire 5000mAh 26650 “Flames”
These batteries has a good performance for cheap batteries, except for the “low” current limit I do not have anything to complain about.
I think the message to take from the **fire discussion is just avoid them. Its a lottery at best, and only in regard to genuine TrustFire is there a chance it will be good, but even then it might not be. Its just easier and more prudent to buy a known item instead.
The blue wrapper trustfire batteries aren’t great. I have had good luck with the 2 14500 foil label trustfire flames myself. I wouldn’t buy any 18650 batteries though. I have so many more Li-ion batteries than I know what to do with at this point from laptop pulls and whatnot, that I don’t need to buy any more cheap cells.
My limited experience with the Trustfire Flames has been good. However, I would only buy Panasonic or similar batteries if I needed any.
Jerry
Odds aren’t good. Goods are odd.
How about this one?
https://budgetlightforum.com/t/-/27736
Some stores sell wrapper that look similar to famous brand.
Btw, do not mean to persuade others to buy, but my experience with Trust Fire 14500 and 26650 is good enough.
Looks like pretty much any battery can be faked. So you stick with a trusted seller and report any problems you encounter. So far I’m comfortable with my TF flames and genuine Sanyo batteries from the dealers I’ve purchased from. Just ordered Efest so hopefully they’ll be a good experience as well. As long as the battery delivers then I’m not going to get hung up on a particular name or brand. And if I can find a good battery at a good price then that’s icing on the cake.
Why don’t bigger ‘name’ companies make batteries like 26650/18650/14500 etc? And at a fair market price? Unless I’m missing something I haven’t seen a Durcell 26650 or an Energizer 18650 etc.
hank - Calmaja and Deputydave are correct: eBay & etc have no shortage of fakes for any brand you want. FT is a good vendor and does it’s best to keep things “on the up and up”. (At one point they listed the wrappers Calmaja mentioned, they were quickly pulled after complaints from BLF users since the only purpose was building fake cells!) They don’t always get it right, but if I was going to buy TF cells it would probably be from there.
You’ve been around here for a while and you still haven’t caught on? The names we keep mentioning are the big names. Sanyo, Panasonic, Sony, Samsung, LG, etc… they manufacture huge numbers of cells. None of these cells are for individual sale. They are intended for use in packs (generally with a BMS). That’s where the small fish like Efest, AW, and KeepPower come into play: they purchase those cells through the grey market. Then they add a protection circuit (or don’t) and re-wrap and sell.
Nobody who cares about liability wants to sell individual 18650’s or 26650’s.
Thank you Wight, I understand what you’re saying.
