Announcement: Banggood has initialized a new brand of outdoor gear.
Here's the link to it: Xmund Outdoor Gear
You can get a 10% discount by using the code: XBD10
Also, I got the following discounts: 12% off for EKEN cameras 20% off for Azdome cameras 20% off for iMars products
Yes. The coupon was $18.99 including shipping to Wales.
If you are looking to buy one now, Banggood has the JYE DSO-Shell (DSO150) for $22.00. The ’15O has an improved layout an improved power supply and a better case.
The only down side is the DSO150 input power is 8V to 10V maximum. The 138 can handle 12V input.
Banggood also have the 1MHz DSO062 and the 3 MHz DSO068. Both are 2M Samples /s or 20MSa/S in repetitive mode. Maybe Bilakos can get you a coupon.
I pulled the trigger yesterday from Amazon. I saw the kits, and they all make noises about not guaranteeing anything, but “longruner”[sic] has an already built version for something like 23bux, plus the test cable.
Might be crappy quality on the leads, but for things like audio, measuring pwm on lights , and so on, it should suffice.
