Okay I’ll try and show a bit more clearly what I’ve done.
I have an adafruit trinket
I bought a length of ws2812b rgb 5050 strip, 144 leds/metre. I cut enough off the end to go around the mirror.
Convex mirror, blind spot mirror for cars.
Some reflective film, silver colour.
Plus a normal glass lens. The glass lens will need the reflective film stuck to one side of it.
All the parts. Disregard the battery protection pcb (it didn’t work for some reason).
Wrap the leds around the convex mirror. In truth it doesn’t have to be convex. You can use a flat mirror. The difference is a flat mirror makes a straight tube / tunnel visual effect. The convex mirror gives it a parabolic shape like a reflector.
Place the lens on top with the reflective tape facing down. The reflective tape acts like a 2 way mirror. When the leds light up you can see into the mirror prism but not back out.
Shove all those ingredients into your project, be it a wall decoration (clock), coffee table or in this case a flashlight
I nearly forgot, I ended up running this code on the trinket. I had to make some adjustments to it - pin out, number of leds, add brightness code and reduce brightness. Kinda happy with myself for getting that to work
This torch works with the head and tail independent of each other. The battery carrier is the same at both ends + in the middle and - on the outer. The rear has a stronger spring so the head makes contact / closed circuit first. Allowing the main led to be used at anytime. The tail needs to be screwed all the way on to power the tail leds. I didn’t make much space for the oring in the tail so the tail is a little stiff and needs two hands but that’s what I prefer if the tail may not be tightened properly when in use.
One thing that disappoints me… two things actually. It’s not focussed the best and thermal step down kicks in fast and keeps kicking. The output drops a number of times within 1 minute…… but that tail makes up for it ….
Cool stuff
1st prize!
Mate that is superb, wow. Well done.
One of the most ingenious mods I’ve ever seen.
If that was on the other end (or both)……theoretically you could still shine light through it too…… Just sayin…. maybe not
Yeah it wouldn’t be so bright - but is it about the beam anyway lol
Sits its all smoke and mirrors without the smoke.
Thanks guys.
I’ll be happy if the magic smoke is never seen
Awesome work, pp!
Makes me wonder how someone even thinks about something like this and you built it.
Very nice!
