PS: I learned this stuff at school from my chemistry teacher. His demonstration was to use his gold wedding ring and a strip of zinc in some electrolyte (very strong acid, got the zinc fizzing), and measure the electropotential. We all worried that his wedding ring might dissolve. No chance.
During the specification choosing process, I was thinking of a steel spring’s electrochemical properties, not a copper alloy spring. I do not know why.
Thanks a lot for the reminder.
This is why I initially asked the question here yesterday. For some reason, I was feeling something was wrong about combining copper and zinc together, because I noticed every book/Internet source that I checked never spoke about zinc plating with copper, but instead, with gold/nickel/tin/silver/nickel-tin.
I was worried I was wrong somewhere, and I was!
Thanks again guys a lot for your help.
TLDR: Nickel-tin plating it is, applied in two separate layers, nickel being above the BeCu substrate protecting it from the tin above, and allowing for good solder ability, along with sufficient softness to allow for excellent contact with the cell.
Easier to solder a bypass because you're changing an insignificant amount of spring (thermal) mass?
Nickel plated and then tin plated? How is the raw tin plating going to resist being solder heated at and above tin's melting point (232°C)? I guess it should do 0K because the soldering heating is quite momentary…
Is the employed BeCu alloy even nastier than nickel with regards to soldering?
Actually, BeCu can be more easily soldered than Nickel. The reason for a plating is to protect the BeCu from corrosion, especially when soldering. I did notice this behavior on the Carobronze springs, which are not plated.
The science behind nickel-tin plating being so good in regards to soldering is because tin alone, while being very easy to solder to, if it soldered without having something like nickel under it, it will have a tendency to form whiskers, which degrades contact resistance.
Adding nickel as a substrate to the tin allows us to solve that problem, and also granting a layer of corrosion protection.
Nickel alone has the problem of being very hard, so contact resistance is inferior to tin.
Therefore, nickel-tin is the best bet for our spring, and should have the advantage of being easy to solder to, having good contact resistance, and preventing the BeCu from oxidizing, especially on 250°C+ soldering temps.
I know I’m coming in late, but if they are still available, I’d like 25 of the large, and equal interest in a similar quantity of smalls, if they get made.
