BLF Interest list for Very High Current Beryllium Copper springs Pt1(ENDED)
Thank You
Thank you for the UPDATE sir, looking good!! :+1:
I’m late to the game BlueSwordM but I would like 50 of the large springs if you can.
List updated.
We are at 1932 big springs, and 1383 small springs.
There are 18 big springs left before I close the big springs group buy.
Could I please add those 18 big springs and another 10 small springs to my existing request?
If it went from 12mm to 11mm that is about 8% loss. You should also try keeping one fully compressed overnight or longer which is similar to being in a flashlight.
Can you remind us how the other two springs responded to similar tests?
That is really good, all springs loose some length upon first compression. If they feel stiff and “springy” I think this is a winner!
And if indeed these springs perform mechanically well and already one flashlight manufacturer uses them, more will follow, at least for hotrod flashlights.
One thing I’m curious of is if these springs will still collapse with really high current (40+ amps), and thus still maintain a safety function. My first guess is: no.
I’d like to know how it handles being compressed while under load, like carrying 6 or 7A through it while smashed. Does that bother it, or not?
Given a choice I prefer to not have the spring compressed beyond about 60% but I don’t always have that choice. Sometimes I can modify a light to give me that, sometimes it’s not so easy.
@DBCustom, I’ll try it out later today.
I can’t do that now, because I’m working until 4PM. However, I don’t think 6-7A current will be much for it to result in more plastic deformation. Although I am going to test at 6A of course so it is easy to compare with djozz’s spring test.
@JasonWW, we went from a 12mm to a 13mm tall spring. That was to offset the plastic deformation that was going to occur.
The Kaidomain phosphor bronze spring lost a lot more height. Around 2,2mm. Losing 2,1mm is about 18% height. Not as bad as the Intl Outdoor spring which lost over 20% of its height when fully compressed, but still worse than the spring I made.
The Fasttech spring. Well, having a very small top and a wide base, along with thinner wire and being quite tall for such a small spring, it loses a lot of height. The worse of the bunch when fully compressed. That was expected however: having a small top diameter, a wide base, thin wire, well, this leaves a lot of room for plastic deformation.
@djozz, their mechanical properties are great. Not as good as steel obviously, but still way better than the Intl Outdoor spring, and even the phosphor bronze springs.
And they won’t probably work as fuses in most cases as you said.
I’m still waiting to test their electrical properties though.
@skinny_tie, you now 48 big springs and 40 small springs.
We are at 1950 big springs, and 1393 small springs.
The big spring groupbuy is close.
The small spring groupbuy is still open.
Can you give us the fully compressed height?
I’ll get to it when I get home.
Edit: Fully compressed, it goes to to 5mm if I remember well.
VERY IMPORTANT UPDATE
Now, this is the part everybody has been waiting for.
I first off soldered 18AWG wire to both end sides of the springs.
Happy to finally do the testing, I then took the 10A constant current tester I had, and then set it to 6A, for good measure :smiley:
So, I tested the spring at a constant current of 6A during a duration of 30 minutes for temperature to stabilize, then measured the voltage drop over the entire spring.
Let’s just say the first results were… worrying to say the least.
I was quite worried at this point. I was off by my calculations by 30%, which was bad.
I retried putting my multimeter everywhere on the spring. I rechecked the load current to see if it was set too high, which it wasn’t. I even tried my other multimeter to check if it was off. It wasn’t.
But, then it hit me. I looked close upon the top joint, and I noticed it was… quite badly done, and was holding quite badly actually. I then just pulled it and it came off
Being angry about my bad job, I then redid the soldering of the top joint, and now it was done way better
The first soldering job was way worse.
Then, I redid the tests, and voilà! It came exactly on target at 52,9 +/- 1,3mV of voltage drop over the entire spring, as calculated. I was so worried there over a very bad solder joint.
BTW, three things:
  • As per DBCustom’s request, I did the test running the spring at 6A, and compressing it yielded in no further plastic deformation. Which is great!
  • Well, the spring heated up just a bit above ambient, but 0,35W of power loss is noting to worry about. 15A is probably the highest current you should go with this spring, as at that point, you would get about 1,95W of loss, which is high, but expected at these power levels.
  • The spring was much easier to solder on than a steel spring.
  • TLDR: All, in all, I was pleasantly surprised with these springs. They are excellent high current springs. I was worried a bit at first, but then, I red
    Excellent!! Thank you for the detailed update BSM…. :slight_smile:
    Ok then. I will start preparing the shipments for the biggest buyers, which ordered 110 total springs or more:
    - MRsDNF at 120 total springs = 60 big springs + 60 small springs
    - teacher at 160 total springs = 100 big springs+ 60 small springs
    - ASF at 200 total springs = 100 big springs + 100 small springs
    - Texas Ace at 150 total springs = 100 big springs + 50 small springs
    • DB Custom at 150 total springs = 100 big springs + 50 small springs
    If you have a total of more than 110 springs, it is actually slightly more expensive to ship big and small springs together. So I will ship the big springs to them first.
    Also, the final price per spring+shipping has been decided:
    (0,30$US/spring + 5$US shipping internationally) * 1,05 via Paypal Goods and Services
    Go ahead and increase my order to 100 big and 50 small so the total works out to $50 total and let me know where to send payment.
    I really can’t afford these but I know I will regret it if I don’t get them while they are available.
    Tue, 07/31/2018 - 09:22……… #329
    @Texas Ace, you already have 100 big springs, and you have been upgraded to 50 small springs.
    We are at 1950 big springs, and 1403 big springs.
    The big spring groupbuy is closed
    The small spring group buy is still open.
    Will you be PM’ing us your PayPal info BSM??
    Also… Do you want the people above to go ahead & send payment for small springs also??
    Thank you again!! :+1:
    Can you add 15 small springs to my order?
    Thanks
    @teacher, yes soon enough.
    I’m currently preparing the orders for you guys so I can ship them tomorrow, and it will take quite a bit of time to count everything, but yeah :+1:
    And, yes. You can send the payment for both the small and big springs if you WANT/CAN.
    If you can’t pay right now for the small springs, it doesn’t cost more because of math.
    But if you want to pay now, that would be nice.
    @JasonWW, you order has been upgraded +15 small springs.
    We are at 1950 big springs, and 1418 small springs.
