With āmodernā fully charged Li-Ion high drain cells I woud rather expect more damage then less.
I was even able to collapse the springs of a flashlight with shorted Eneloops AA (Thrunite TN4A).
Yeah, I was only talking about cells doing direct damage to themselves and to other directly connected cells. After the power leaves the cell and enters the springs, the host, the driver, and the emitters, there are lots of things that can happen. I collapsed some springs from ānormal useā in a Q8 by only changing the emitters to SST-40 and turning off thermal regulation. Actually, was in the middle of āsettingā thermal and didnāt get it āsetā in time, so it happened while the light was running in Turbo.
Thank you & the others for the welcome shirnask. I have been watching this develope for a long time now. Finally just couldnāt stand it anymore & figured I bettet get on the train before it left the station.
I think this lantern will work well in our High Country camps.
When all the hunting seasons have ended in different areas & everything is packed up and secure, I usually go some place warm for a while.
Splitting time between Everglades City FL & Port Eades LA.
Nothing is final, but the talk has been that 4 or 5 channels would be enabled on the production lanterns. If you want to enable more, it will require connecting two solder pads that are very close together. A simple way to do that is to connect them with melted solder. I suspect some clever person will come up with a way to connect them another way without solder. I have some ideas, but Iāll withhold them for now.
Regarding tint, the lantern has two sets of emmiters, one around 5000K, the other around 3000K. You will be able to adjust the tint between only 5000K driven, only 3000K driven, and pretty much everything in between with a mixture of both sets partially driven.
That sounds good, except i wouldn't want to try to change anything on the lamp bcoz im not good at all with electronics & i don't want to stuff anything up on it, but that's great about the tints..
Iāve never used them but they sell electrically conductive epoxies that you can use to attach wires connecting the pads together or maybe even use the epoxy to directly connect the pads.
Personally I would just use solder to connect the pads since itās not all that difficult to do .
