You only need the six pads in the 2x3 array as labeled. Use some jumper wires to match the wiring between the programmer and the cable.
You'd be able to use the pogo pins as well, there's a pin header on that side as well after all. Just need to manufacture a cable that swaps signals according to the needed pad arrangement.
I'd expect six just loosely held wires to be a quite dodgy connection.
I meant using both sides ā the programmer and the pogo pin PCB ā and connect them with jumper wires. Or is Hankās pogo pin adapter just 2+4 instead of āfullā 4+4? In that case it can still be used ā just omit ground or V+ and connect it directly to the flashlight.
Oh lol, sorry for the misunderstanding. Yeah that'd certainly work
Everything should be labeled. Here is a photo of the latest revision: https://i.redd.it/bzi7l3tlaui51.jpg
It is
RST V+ GND
SCK MISO MOSI
Does anyone have a rough estimate as to how long moonlight will last with 4x 3300mAh cells?
5x AMC7135: 5 * 0.35 A = 1.75 A
1/256 duty cycle: 1.75 A / 256 = 6.8 mA
LED + MCU: 6.8 mA + 2 mA = 8.8 mA
Battery capacity: 4 * 3300 mAh = 13.2 Ah
Estimated runtime: 13.2 Ah / 8.8 mA = 1500 h = 62.5 d
Probably much less due to other losses.
Estimated runtime: 13.2 Ah / 8.8 mA = 1500 h = 62.5 dProbably much less due to other losses.
I appreciate it, many thanks
I know this wasnāt your question but thought it may also be usefulā¦ā¦.
I enjoy candle mode. I did a runtime test in low candle mode starting with 30Qs@ 4.2v. After 21days - 24/7(total of 504 hours) the onboard voltage reported 3.4v.
Havent flashed my original version yet but realized I lost the usb rubber cover for the charge port , any ideas? I didnāt see parts listed anywher e.
Recently I got my BLF LT1 and it has a spare USB cover together with the spare o-rings. You should ask Sofirn if they can send you one. They should have it available as a spare part.
Do you know which screws (with which dimensions) to buy and that would fit the BLT L1 screw holes ?
I ordered these ones (flavor āLS047ā / screw 4.5mm + additional height 3mm), and sadly they donāt fit well (and not in the same way between hole on the side versus at the bottom = it goes deeper on the side) (and i havenāt been able to find models without the āgapā in the middle).
https://fr.aliexpress.com/item/4000767201624.html?spm=a2g0s.9042311.0.0.27426c37KX5AC1
Never tried but Iām 99.99% sure these would fit.
You simply need standard photography tripod screws. Nominal size is 1/4-20
PS: ces vis sont disponibles au sur Amazon Canada, jāimagine quāelles le sont Ć©galement sur Amazon France ?
Is there anyone willing to try my custom 16 bit build of Anduril 2 for the LT1? Iād love to get some feedback on it.
It provides nice and smooth tint ramping and much less tint flickering when dimming at low modes, itās just that the brightness curve is somehow bumpy and I havenāt figured out why yet (I actually suspect hardware non-linearities). I havenāt seen anyone else do this yet (faking 16 bit on an 8 bit capable MCU).
I can provide a zip with the source code and hex file to anyone interested (I still donāt understand how to add my code to TKās firmware repository without considerable effort).
Sure, Iād like to give it a try! How bad is the bumpiness?
Barry kindly sent me some real pictures of the new LT1 colors. I think their anodizing team did a pretty good job, didn't they? Maybe we get to see these new colors packed with new features like full USB-C compatibility (PD charging) as well as reverse-charging, i.e. to use LT1 as a powerbank to recharge external devices.
only 2 new colours?
I really like that dark green. The other one just looks black on my monitor; how would you describe the color, Lux?
Barry kindly sent me some real pictures of the new LT1 colors. I think their anodizing team did a pretty good job, didnāt they? Maybe we get to see these new colors packed with new features like full USB-C compatibility (PD charging) as well as reverse-charging, i.e. to use LT1 as a powerbank to recharge external devices.
Looking good! - My apologies for my limited correspondence over the last number of months, been crazy busy with the big move, settling in a new house, all that. I hope to chat more with Barry soon on the colors versions, accessories, and the Mini LT1 once i get back on my feet.
So where do I sign up for the green one and how soon can I get it?
only 2 new colours?
I assume theyāre just using what theyāre familiar with. These look like the EC01/3 colours
