I generally order mine off their Chinese website and get them in under two weeks. I get charged sales tax (marked as VAT) but, shipping is free and delivery is fast so I keep going back to their store.
My recently delivered LT1-A2 was received in Advanced UI mode, and set to stepped ramping.
There obviously seems to be some inconsistency in how the units are actually prepared, and shipped, making any assumptions tenuous. Perhaps the same folks who (inconsistently) run Jinbaās labeling machines also prepare and flash the drivers. Any bets on how many āSofrinā lights have made it into the wild? There must be at least some.
My unit also left the factory with the switch and its lights clocked at 10 degrees off vertical (not unlike thisreview sample), which my OCD would not allow to go uncorrected.
I was not aware of how the switch PCB and well it rests in are designed, but discovered that they are indeed shaped/indexed to prevent this, and it was a result of sloppy assembly practice that resulted in it being misaligned.
That said, those were the only lapses I found with mine, and overall, the LT1 is quite pleasing and deserved of its reputation.
I donāt mind the much-lamented green switch illumination of the newest revision, but the blue is kind of odd, and I wish the blinking mode was more like the breathing/pulsing mode like the SC31B had. Not sure if that is the result of intention, or a limitation of some sort, but a more refined implementation would actually make it usable in my book.
Last thing I might wish for is some Anduril documentation that is a cleaner, happy medium between a spaghetti-like chart and a wall of text.
Some ship with Anduril 1, and some ship with Anduril 2. The version check function (15 or more clicks from off) should show which version it has:
2020-06-02 or earlier: Anduril 1
2020-07 or later: Anduril 2
As for config differences, those can be wiped out using the factory reset function. Loosen the tube enough to break contact, then hold the button and tighten the tube. Keep holding the button for about 5 seconds, until after it flashes at full power, then let go.
Itās a good idea to factory-reset any new Anduril-based light, at room temperature, to reset the config and calibrate the thermal sensor. Generally I also write down what version check says, and then reflash it with the latest firmware.
The ābreathing modeā isnāt implemented because it requires keeping the control chip awake to do pulse width modulation on the button LEDs, and this greatly reduces standby time. A breathing mode eats up the battery about 40X faster than the blinking mode. It varies per model, but in general itās approximately the same power usage as just leaving the light in moon mode all the time.
Another issue is, on many lights, the button LEDs and aux LEDs arenāt connected to hardware PWM pins, so it would have to be done manuallyā¦ which looks glitchy due to timing issues. Instead of being smooth, thereās typically visible noise in the signal.
So instead it does a 2-level blinking pattern. Itās energy-efficient, reliable on lots of different hardware, and doesnāt use up much ROM space.
I ordered the latest Anduril 2.0 version from the AX store, which has the fifth-generation (IIRC) āBLT-LT1-A2ā driver, green/blue switch LEDs, and power bank function (the last of which I have yet to test). The package label also identifies it as āQ8LT1ā which someone suggested also indicates the latest version.
After being taken out of locked mode, it turns on, which according to a simple tip, indicates itās running Anduril 2,
However, unlike my SC31Pro, which clearly blinks out the expected version (2020-03-18) during a version check, I get an odd result from the LT1, seemingly with extra digits:
2-0-2-0-0-1-2-5-0-6-2-1
How should that be interpreted?
Iāve performed the thermal calibration with my other lights, but have read that since the LT1ās remote LEDs arenāt close enough to the sensor to get a usable reading, the thermal functions are disabled, or at least, rendered moot. Is that not the case? Should LT1 owners perform the thermal calibration procedure in any case?
Thanks for providing a clear, and logical explanation, which is often not returned in these, and other discussions.
Hmmmmā¦ā¦ I was looking at the numbers TheIntruder used in his question
ā 2-0-2-0-0-1-2-5-0-6-2-1 How should that be interpreted? ā
ā¦. not the videoā¦.
I suspected the last few digits might be a variant, or sub-version of some kind. Is that an Anduril 2 thing?
More puzzling was the 2020/2021 discrepancy. I could have sworn I repeatedly saw an extra zero before the one, but after further review, I now see it correctly. Maybe I need to lay off the sauceā¦
Further observations ā I donāt intend to rely on the power bank feature, but tested it anyway to verify that it works. It does, at least for a short observed period. I assume that the amber āsufficient chargeā indicator that remains lit for a brief period after the cable is detached applies to both when the LT1 acts as a source, as well as the sink, and being charged itself. The wording in the manual is vague, and doesnāt note that.
Charging the LT1 via an A-to-C cable results in the flashing blue indicator, as expected. However, charging it via a C-to-C cable results in a flashing amber, not blue, indicator. Is that the expected behavior?
I like to have digital equivalents of documentation, and since I havenāt been able to find the manual for the A2 version, aside from a photograph of it, Iāve scanned the printed manual myself (despite whatever E&O it may have).
This makes zero sense. Did Sofirn make another version of the mcpcb? :person_facepalming: Can you take a clearer picture so we can read what is on the mcpcb?
It looks like there are few versions of Sofirn A4 boards now. The questions about the flashing key have come up already.
I am adding one more. Those 8 pads, 1 through 8, are probably corresponding to the pins, 1 though 8, on the chip. We need to confirm it. My question is more basic. Is it just me that the alignment of those pads looks like curved, not straight? If it is indeed curved, it looks like straight enough. So, the pcb for the key from Oshpark probably works, assuming the spacing is OK. The pins just need to be wired correctly.
By the way, I can see it is the āA4ā board in the picture.
It does have a powerbank function, didn't get it to work yesterday with the same cable for some reason. The version is 202108290621. Here's a better lit picture:
