All temperature functions are disabled in the LT1 because the thermal sensor is too far from the LEDs to perform any regulation. Also, it needed the extra ROM to make tint ramping work.
If Sofirn produces a newer version with a bigger control chip, like attiny1616, it should include the thermal functions again, even if itās still too far to use for regulationā¦ because at least then it could work as a crude thermometer.
so you also donāt have the external temperature calibration menu? it seems strange to me, moreover the 13h to reset does not work, I am thinking of having a faulty lt1
All temperature functions are disabled in the LT1.
Different build targets have different configurations. The 13H reset has traditionally only been enabled on lights which canāt do the loosen-hold-tighten reset method.
It doesnāt sound like thereās anything faulty about your LT1.
So today I finally removed the 0 ohm resistors to lower the brightness of the 2700K leds. The idea was to keep the 5000K ones. But the WW side is connected to the 5000K leds and NW to the 2700K. Why oh why!? At least the PCB solder bridges are a very nice addition and easily resolved the mixup. I did notice the same WW/NW mixup on the MCPCB in another LT1 that I took apart for an emitter swap. The silkscreen doesnāt match with the LEDs, so this one probably has the same mixup.
Btw, concerning the Anduril 2 driver. Compared to the rev 5.0 driver, does the hardware offer anything new other than power bank functionality? Was thinking of maybe flashing the rev 5 to Anduril 2 if possible.
As Toykeeper mentioned, the temperature are disabled, as they are not needed in the LT1. ( The LEDs & heat sink are at the top (head) of the lantern & away from the driver & battery body area, meaning he driver & batteries are away from the LED heat.
i have an early (first?) release LT1. i found 1 below the top level of stepped is sustainable. top level gets hot.
i donāt know what rev firmware i have, as tracking the flashing is tricky for my old eyes/brain.
My orange LT1 (box labelled Q8LT1) from Sofirnās AliExpress shop shows BLF-LT1-A4. One difference from the BLF-LT1-A2 is that the indicator LED is now orange. Perfect. Any other differences?
I love how the indicator LED automatically adapts to the main lightās brightness: dim at low brightness, and high at high brightness. Such attention to detail, just fantastic!
The orange anodizing looks gorgeous to me. It looks slightly bronze-ish in some images below due to the camera, but itās more orange in person. I was also very tempted by the green option, but figure a more visible color is useful to avoid losing it!
Some questions:
The only way I found to get out of momentary mode (5C from ON or OFF in Advanced UI) is to unscrew the lantern until power is cut. Is there another way? The UI map shows this mode is a dead end.
Sunset mode is reducing brightness in steps, even if the light is set to smooth ramping. Any way to have it decline smoothly?
Itās surprising how pleasant and nostalgic candle mode is, especially in the warmest tint.
Big thanks and congratulations to all involved in the LT1 project!
Ah, makes sense, and in that case itās actually a cool feature. The UI diagram should probably still indicate how to exit this mode, even if itās physical vs electronic.
Other observations:
2H from OFF in Advanced UI is a turbo momentary, unlike what the UI map shows.
The ramping seems to go all the way to max/turbo level. Maybe I misunderstood, but it seems the UI map shows ramping or 2C to reach the ceiling level, then a further 2C for turbo. Instead, a second 2C just returns to the previous brightness for me.
Btw, Iām looking at the 2021-08-02 revision of the UI map for the LT1.
As the saying goes, the biggest room in the world is the room for improvement. Fading in steps is a bit jarring, but Iāll survive.
The floor and ceiling levels are configurable. On the LT1, the default is to allow full power because itās not a hotrod light. This can be changed though.
About fading in steps, itās mostly because of the power circuit having coarse resolution at a hardware level. Iāve been thinking about ways to work around that, but the only solution Iāve come up with is really complicated and would require pretty major changes to the code.
Basically, the hardware allows for 256 total steps including āoffā. When the light is at level 5/255 and needs to fade to 0 over the course of 5 minutes, itāll slowly drop to 4 then 3 then 2 then 1 then shut itself off. These steps are quite visible.
To fix it, Iāve been thinking about making it alternate between levels very quickly, like at 16 kHz. So instead of dropping from 2 to 1 all at once, it would go 22221 for a while and then 21221 for a while, then 12121, then 11211, and then just 1. And each step there would last for only a fraction of a millisecond, so it would hopefully look smooth by eye. But to make it work, it would need extremely precise, consistent timing, and a bunch of math, and some core parts of the code would need to be completely rewritten.
Soā¦ for now, the steps are still visible during low modes.
At high levels, it doesnāt matter. Dropping from 240 to 239 isnāt a visible difference. But dropping from 3 to 2 sure is.
I see, so thatās what it means when the UI map mentions that the factory default ceiling is 150/150. Now it makes sense. I confirmed that turbo works as expected if the ceiling is reduced. Interesting, and ultimately the default makes sense.
Thanks for that explanation. The proposed solution sounds clever. Before even trying to implement it in Anduril, has the eyeās perception of this strategy been tested?
In any case, itās already amazing how much Anduril can do and how it spices up the LT1. Thanks for your efforts.
Can anybody help me out? I have been gone for so long that I donāt even know if I had a user name so I had to create a new one. I was here when this project started, but never bought the lantern. I am getting ready to buy one or two and the mini later. What is the current status of a 21700 version, distant future? Should I just get the current version? I am a bit confused on their Ali store because I remember the whole problem with the USB-C and want to get the latest version. I assume that is the one listed as New Anduril 2? The price is really good right now! Thanks for any help in advance.
There has been some discussions on a 4 cell 21700 version but not much more than that. If it was me Iād get the current version because it could be some time before a decision is even made on producing one.
Thanks for the reply. I decided on one plus 2 of the LT1S and a flashlight. Now I am remembering why I never orderā¦ they never have the pretty colors they show.
3*21700 in the center of a Nalgene sized, full-body diffuser with a third red channel in addition to the two tint ramping white channels. Waterproof and floats.
