BLF LT1 Runtime test *updated 12/11 with step level 2*
There is not a set of instructions specific for the LT1, but I will point you toward a helpful thread. First a few comments.
There exists a device I believe you can purchase that will interface with the programming pads visible at about 3 o’clock in the picture below. not a great pic, but I think you’ll get the idea. Lexel sells them. I’ve bought a D4 aux light board from him, he sent it quickly, and his prices are reasonable. I just haven’t ever motivated to get one of the programming keys, maybe some day. First the programming key pic, then the driver board with the pads at 3 o’clock.
I’m noticing more pins on the key than pads on the board, guessing you can/would figure that out, or Lexel could tell you.
In the event you don’t want to go that route, you will need an 8 pin chip clip to interface to the Attiny85 chip. This thread has lots of info to get you going. I used it when I began to learn to flash my D4. The only SW you need to load is the AVR Tools and the USBasp driver, unless you want to write/modify firmware, then I think ATMEL studio is useful (I’m guessing here).
Hope this helps, ask more questions as desired. :slight_smile:
Here’s the command if you want to flash the 27b version firmware Toykeeper posted above:
avrdude -c usbasp -p t85 -u -Uflash:w:anduril.2019-11-27b.blf-lantern.hex
