I would like to know where did you get your VTC6 button tops….
From Aussie eBay seller supersports600. I don’t know if he ships internationally. http://stores.ebay.com.au/supersports600
Tom has the NarsilM v1.2 BETA cooking and it will have a modus with momentary on.
Maybe it’s usefull for light painting?
And Toykeeper said she will have Andúril for the Q8 .
Nice review.
I was being a bit picky complaining about lack of momentary in the Q8 as it isn’t really a tactical light. However having momentary as an option for Narsil would be great, especially for 18650 tube lights. I probably should contribute to the Narsil thread.
Hi StephenK
Thanks for the review
The X-Ray sure provides a different insight (like what I did there?)
I wouldn’t put it past you not having a spare CT scanner lying around - look forward to that review!!!
Ha, I do have a CT scanner, but can’t justify the radiation use. The x-ray images are taken during routine tests, so have to x-ray something.
Some outdoor beamshots taken last night with the BLF Q8. The Q8 was only on approximately 33% output!
Warm white Convoy S2+ used for a bit of foreground lighting.
And great nightshots too - very skillful
Thanks. I had to use the Q8 on only 33% output so that the cloudy night sky would not be over-exposed. The Q8 on max is quite a revelation!
Niiiiiice! Thanks for the nice review and shots. Can’t wait til I get my hands on one of these, unfortunately mine are still on the slow boat from China and I don’t expect them to arrive for another 4 months or so.
Nice review, Thanks.
Great pictures too.
I also practice vape and lights too… and spend quite some time watching the evolving and intricate structures revealed by an intense beam of light.
The X-ray shot i saved for reference. It should be printed on the Q8 box IMO.
Another photo with the excellent BLF Q8 on full power, with Fenix AOD-L diffuser. 3sec exposure, f/14, ISO400.
Nice picture Stephen!
You are right the values for modes in the two manuals are different. I changed this in the new cheat sheet. And I added also a few notes for starters.
Could you add this line in your review somewhere at discrepancies between these two manuals ?
(A newer version of the cheat sheet is under http://bit.ly/narsil-cs )
Joe
Done (in a few minutes)!
Thank you!
After rereading your review:
A newer version of NarsilM v1.2 has a momentary mode. Activated by 5 clicks. There is no command to stop this mode you had to disconnect the battery. So you can morse really fast.
If you can flash firmware you should try it.
Thread NarsilM - configurable e-switch firmware for Multi channels, v1.3
