Barkuti
(Barkuti)
41
Dominant wavelenght range is 457.5 - 462.5nm for the 08 kit code. Quite good emissivity at 465nm thus it should provide. Closest kit code is 06 (460 - 465nm DWL range), but found nothing.
If you have never reflowed surface mount components it may be a good idea to ask for help if you have some expert at hand, or learn by yourself. Buy some extra spare blue emitters and maybe a bunch of cheapies to try and burn. Cheap copper MCPCBs here if interested.
Careful lay out of the solder paste, emitter placement, press down and paste excess toothpick removal, slow temperature ramp up and down, tight control of the temperature window, etc. There are some reflow diy videos out there, practice and calmness are good allies.
These XT-Es are not the cheapest, look for example at XP-G3 royal blue emitters for comparison. Highest flux bin Opulent Americas starboard mounted emitters available, by the way. No idea if those are DTP stars. That option may still work nice enough.
Cheers
P.S.: Aaah! Didn't noticed it was you klrman, thanks a lot again. :-)
klrman
(klrman)
42
Cheers Barkuti, you're welcome
Ok, I have to give it a go and get some cheap emitters and learn how to reflow. Thanks for all the above info, very helpful
Henk4U2
43
I read the same in the litterature but hé, I’m red-green colorblind.
Or as the waiter Manuel in ‘Fawlty Towers’ always says: “I’m from Barcelona, I know nothing. Noo-thing”.
But here is a picture that says you are correct:
As for bloodtracking, these are the two most prevalent opinions
- take a flashlight with a green led and a red led, throw in a special filter and ALL red objects stick out like a sore on a baby b* while the rest gets a brown blurr.
- take a flashlight with a blue led, and the blood becomes a black spot while the rest basks in the blue light. Because the absorption spectrum of bloodplasm matches the emission spectrum of the blue led.
Jerommel
(Jerommel)
44
Hmm… One would suspect Cyan (480 - 490 nm) to be better, because it’s the opposite of red on the ‘colour wheel’.
Another thing, isn’t blood plasma the blood without the red blood cells?
But finally: Don’t mention the war!
Henk4U2
45
Here you have the LINK.
And last but not least: You started it! :smiling_imp:
I made a video testing all of the different options here if you guys are interested. TEST of Blood Tracking Flashlights!
pc_light
(pc_light)
47
FWIW, I have an old Nitecore CU6, which in addition to the main white LED has UV (3W-365), and 5mm Blue, Red and Green LED’s. For this discussion I tested it out on some blood.
I should mention that the original white XP-G2 has been reflowed with a 4000K LH351D, for warmer high-CRI output.
Similar to VestureOfBlood’s results I found that -
(1) no single color made the blood jump out,
(2) high-CRI white was relatively the most effective,
(3) red made the blood disappear and under green the blood was the most contrasty almost black. (Unfortunately, the CU6 doesn’t have the ability to operate green and red simultaneously), and
(4) UV without Luminol didn’t do anything.
Don’t waste your time and money… Watch this video.
Your test results are pretty much in line with Matt’s from Adventure Sports Flashlights.
