Hmmm Itās not ash, itās not hickory, and itās not oak (or at least not the usual variety). Way too dark to be any of them.
Yeah, Iām drawing a blank hereā¦
I got that from a friend of mine about 15 or so years ago. It came from a railroad tressel? bridge up here in the northwest. I have 4 pieces each about the size of a 6āx10ā and about 10 feet long. They weigh over a hundred pounds each. Neat stuff.
Here is a decent site I like for identifying some of the mystery wood scraps Iāve accumulated over the years for turning. It takes a bit of time and a high-bandwidth connection due to the nice pixtures, but it has helped me innumerable times.
Since railroads generally used the woods found along the track route, & it came from the PNW, hereās a list of trees common to that area.
As to your mystery meat, it looks a lot like White Oak heartwood, but thatās just a WAG. If we knew the location of the donor trestle, that would helpā¦
Please donāt leave us wood lovers hanging?
Dim
Hmm, my first guess was teak but coming from a trestle that doesnāt sound right. Iāll have to do one of each and see how they turn out. If Iām careful I might be able to get 4 18650 blanks for each 2 1/2ā length of 8/4 and 1 18650 + 3 14650 (Micromag) from the 7/4. Enough wood there to keep me busy for a while. In any case I wonāt be tossing anything unless itās too small for even hearing aid cells.
Did some ggg and teak was used sometimes in RR construction for itās strength and rot resistance. If it is then you got some $ there JA.
Iāve already done a touch switch. The two brass studs at the top of the leather grip activate the red laser. Just move a thumb to turn on/off.
this is IMHO misuse of a time machine and might alter the course of human history .
you have been reported to the time police
Hey Scott, these look awesome! I love the way that oiled oak looks on that bare A6. I want one.
For those that have not seen the build thread on the RBD ray gun light heres a link to the build thread.
Just an idea courtesy of slim and only a faint notion how to pull it off. Some copper, brass, aluminum, and hopefully the ingenuity to make it work. Hereās the idea [image] And some of the raw materials. [image] Doing this well and in time will be a stretch but here goes nuthin. I couldnāt find thin wall brass tubing in an affordable length so Iām going to try to roll sheet brass into shape. Iām also going to try and fit 3 - 18650 cells(2 in the handle and 1 up the pipe. [image] I succeeā¦
I for one dont understand the patience this guy has. His abilities and creativity are second to no one.
Iāve cut single cell blanks for A6 and X6 tubes using all the woods I have and drilled 3 of them for brass tubes, curly maple, black walnut, and the mystery wood which Iām still leaning towards teak but no expert. I only have a couple shorty tubes and ordered some more but the possibilities I have on the shelf are A6 and X6 of course, plus C8 , Solarforce L2, and Minimag AA tubes(specify length). I havenāt yet glued the threaded ends on yet as Iām not sure which one Iād like to keep. They can be done with or without the clip land, using the stock aluminum land(as pictured above)or milled from the wood section.
Not sure if I want to know why no one copies me.
My thumb tells you why I dont copy you.
I got to see this one in person last weekend when Scott brought it to the mini BLF get-together.
Gorgeous!
Curly maple sounds like it would be beautiful on a bare aluminum tube light, like my A6. Dibs!
Seriously though, Iām not kidding when I say I want one. There are no prices listed here and Iām almost afraid to ask, but I really am interested. I think Iād want mine with all bare aluminum, so based off of a bare aluminum tube. My bare shorty tube has been in shipping for weeks and isnāt here yet but when it finally arrives I may just turn it around and send it to you.
Sorry about the lack of pricing, I was holding off until I made sure I had something worth doing and paying for. Do you use the clip? I can make the wood slightly shorter and leave the aluminum clip section as part of the tail threads or eliminate it (no place for clip but more wood) or turn the wood for the clip to clasp wood instead of aluminum(this would cause wear on the wood but some might prefer it anyway). Also, for those that do spring bypasses I can make them a few mm longer to reduce spring compression and flex of the bypasses.
emarcd, Let me know via pm what features you want and Iāll make it to that spec whether you end up buying it or not. For now the blanks will just get turned to the correct OD.
I got the tubes glued into the blanks a few days ago and was able to spend a few hours today turning them on the drill press and giving them some oil finish. Lots of hand sanding and grain raising in between as well. The ends arenāt trimmed square or to the proper length but hereās a taste of how they look on my bare A6. First the Maple with natural stain.
Then the Oak with natural stain again.
Mystery wood, still thinking Teak since it has the color, density, and prominent light colored pores with a dark Walnut stain.
And finally Walnut with dark walnut stain.
Here they are side by side to show a better grain and color comparison. I just received my order of A6 and X6 ano shorty tubes (short one X6 tube) and will ream and cut an X6 tube so we can see how they look against a black ano host. Also will be prepping a few more samples including the White Oak, Redwood Burl, and Mahogany. I havenāt ordered any bare shorty tubes which is why you see the black one here.
They all look good but that mystery one especially so. It will be interesting to see how the others look.
wauw! Thiss looks amazing!
Awesome! I think I like oak the most
