I saw it, the listing states that he only ships in the US. I might as well send him a message.
Edit: Unfortunately it doesn’t look like I can contact this seller via ebay.
If I use the contact form I get this message:
We’re sorry we couldn’t find an answer for you. Unfortunately, this seller is not able to respond to your question. We suggest reviewing the item again to see if your answer is in the seller’s listing.
Something else though, i thought it was mentioned somewhat already:
I read here and there that when you put some current back into the device, like when you have a spinning motor or a charged battery and you turn the power supply device off, it may be damaged.
This is indeed why it is advised to charge batteries with a diode in series.
Or make sure you disconnect the load (motor or battery, perhaps even a capacitor) before you turn it off.
Thoughts?
In what Canadian shipping zone do you live? I wonder what it would cost for me to purchase them and ship them on to you? Or I could send the seller a message and ask if he will ship to a Canadian address if I or you place the order. Is it worth looking into, or are you not that interested?
Correct, the smaller units need the diode to protect from this behavior. The 3012 and 5015 on the other hand do not. I have charged batteries many times with my 3012 and says it can do this in the manual.
My 2 EPS-470's arrived just a bit ago. I hooked them up real quick. Not sure what to think about what I saw yet. I have to run. So here is all I know so far:
The are pretty quiet (at least at the low .4 amp load I put on them). I don't know if I had a cord or PSU A/C jack issue with one of the units. It would loose it's connection intermittently. I will have to check that out tonight. It was pretty clear that the connection was breaking where the A/C cord fit into plug in the back of the unit. I couldn't get it to seat well and touching it cause it to totally disconnect. Probably foreign matter on the cord or plug. No time to check out right now.
Both fluctuate output voltage from the high 47's to the mid 48's (Didn't get a lock on the exact range). Didn't' run them very long. So maybe the voltage would have stabilized.
One outputs almost 1/2 volt less than the other.
Connecting them in parallel including the "third" pin mentioned earlier does not make them equally share the load. One unit was outputting about twice the current of the other.
When I first connected them in parallel, one of the units made a repetitive clicking sound for about a minute. I kind of wonder if it was the connection issue I mentioned in bullet one above, because it went away when I pulled the A/C plug for that unit. The lights and fans keep running when unplugged (while paralleled).
I'll see what I can find out tonight, but for now I recommend these units not be run parallel.
In the inside picture a couple pages back, I'm curious what the thing that looks like a jack (the black thin one, not the white 3 pronged one) on the right side of the fans is
What range does your DPS unit show the Voltage In fluctuating? I don't think it will be a problem because the output voltage from my 5015 stayed solid during the whole time I had it connected. In fact, when I was plugging and unplugging the EPS-470's (while parallel) nothing seemed to miss a beat.
I really like the form fact of these EPS-470's. I'm thinking I will put mine on legs so that it will be a shelf to set things on on the work bench. Less likely to pick up debris into the fans that way too.
Starting to play with the idea of connecting these in series to anodize TI. Need to see if the DC negative is grounded and float it on one unit if it is. I think you said it isn't grounded. 96v would take me up to the colors that after the yellows:
I just got mine in, hopefully have time to play with it next week.
I was curious though, have you tried measuring the voltage output directly at the units when under load or only with the DPS input voltage meter?
In my case the wires I use to get the power from the power supply to the DPS are not that thick (didn’t have anything better on hand that was long enough). They work fine but do cause a bit of voltage droop at higher power levels.
Luckily the DPS keeps the output smooth as silk even with the fluctuations.
I PMed the DPS designer and he confirmed what Texas_Ace had already told us, that the DPS board was capable of powering an additional 5V fan in parallel.
