It’s a good feeling to see your equipment happily chugging along when the lights go out.
We had a short outage last night. A distant chirping from the older APC in the far bedroom was all that happened. The other 3 (yes, I know, what can I say?), quietly went about their jobs keeping all my toys safe.
All the Best,
Jeff
Excellent, real world testing is a vital part of preparedness.
Is yours large enough to run stuff till the power comes back or enough time to shut down?
I am considering buying one, we don’t get long outages (we had an hour once in the past 7 years) but i get 2-3 second outages a few times a year and am concerned about hard drive failure.
If I'm playing a game, and the power goes out, I have enough time to save my game and turn off everything until the power comes back on.
It's most important for my PS4 because otherwise I have to wait about 10 minutes for the PS4 to check and see if everything is okay when the power goes out.
I saw one online at Costco for $62.99 iirc, if they have it in store it will be closer to $50. But undecided if i should get it, its not in the budget.
How i wish we could get lithium versions.
Have it charge to 75% max and it would last a decade or more.
And be cheap, a 21700 at 5000mAh with 5 batteries would give about the same power storage as the one i am looking at for not a lot of money in batteries. Heck a powerbank with 25000mAh would do almost the same job and are commonly available and cheap. All it needs is the control circuitry and an inverter.
How old are the batteries, what size and load were on each UPS, was everything plugged into the battery backed outlets? Most consumer UPS only provide back up power to half of the outlets. Depending on the temperatures and quality of batteries, you can expect anywhere from 1 to 3 years before needing replacements. Also small units are usually only rated for a couple of minutes at half load, so a small 600VA UPS may only be able to run 200 watts for around 5 minutes and even less as the load approaches max output. Pay attention to the rated VA vs watts ratings as well when adding devices.
They don’t sound old enough for the batteries to be bad yet, but you won’t know unless you test. You might want to find out the runtime and load ratings for each and perform a runtime test after the batteries have fully recharged. A physical inspection of the batteries wouldn’t be a bad idea as well. I have several Cyberpower and APC UPS and the APCs seem to cook the batteries faster, especially when placed in a confined area with poor ventilation.
You should test the UPSs on a regular basis. My CP gave up the ghost recently after 5 years, which is surprisingly good. My new one came with UPSilon 2000 5.4, allowing for running some internal tests, so don’t even have to switch off RCD for a test.
The PS3 turning on when connected to mains is crap. Is there no switch to really disconnect it?
I suspect it was intentional to preemptively turn on the console when the player picks up the controller, but an override option should be available. Plugging the charger into the UPS will likely make little difference to the runtime, but does use another outlet unless you add a power strip.
RC,
It only takes a few deep cycles to kill off a UPS battery. Perhaps this has happened since you got them.
The only way to tell what’s going on is to test them with a known load.
I made up a bank of 100w light bulbs that I use to test my UPSs.
That way I’m not risking any sensitive equipment and I’ve got a known load.
Slap a volt meter on the output. And, if you can manage it, on the battery as well.
I’ve had UPSs that were seemingly OK with no load - fail with a load attached.
Don’t be surprised if the lights dim when the wall power is removed.
The simulated sine wave supplies don’t “pass the touch” as well as a true sine supply.
Some equipment is not happy with simulated sine wave output - perhaps your Sony stuff is like that?
I would not think so since the Sony stuff is using a power supply to drop the line voltage to computer type voltages.
Did you do some sort of Runtime test when your UPS were new — sometimes if you buy them on sale, there’s no telling what the condition of the battery is in — you’d be surprised how little runtime you get from these single 12v SLA type UPS
