C8 addicts thread
No. I ordered them as ready with some chinese crap pcb. So that is the reason they burned so easily.
Yes, I you want to run the emitter at max amps you need the best heat transfer possible. If you don’t re flow yourself Kaidomain sells the SST-40 on a DTP MCPCB :
http://www.kaidomain.com/p/S026883.Luminus-SST-40-White-6500K-LED-Emitter-with-KDLIGHT-5050-20-20mm-x-1_5mm-DTP-Copper-MCPCB
Here is a video of how to re flow :
Thanks khas! Good quidance video, never done that but now I must get solder paste so I will learn to do that :slight_smile: But first I’ll order ready one from link you put, thanks again khas!
i love my c8 but one thing, i run it on max output usually and it barely gets warm, is this sign of very good heatsinking or? not that i complain but my olight m22 compared gets somewhat hot on the highest.
Modded or stock?
the C8 should get warm but not hot at 3.7V and 2.8A
if not its not getting a high current
the thing is power heats up the light
mass absorbs the heat, but its just a delay
non DTP star hets up the light as fast as DTP, but the LED gets hotter
lumens drop, but a bit more IR heat sended out of the front
I second on this statement. I wish Simon would make one because C8 is a great thrower for a budget price.
I personally would not want usb charging C8. Convoy and Sofirn are very well waterproofed so in my mind it’s better not have usb rubber cover wich can be loosen and get lost at some point. Just my opinion :slight_smile:
If the design of the USB charging port is same like the Jet Beam E10R I don't see any problems :)
It dépend of your use. I mean in 99% I don’t use my lights when raining or leave them outside.
So a rubber cover port is more useful for me than unscrewing… It really depend of you.
I wish it does exist c8 with rubber USB port for my family member.
Maybe my opinion comes from that that I allways discharge/charge mine and familys batteries to see their state. And like I said; only my opinion :slight_smile:
In theory, they can recharge it from a usb battery-pack, but it’s terribly inefficient, charging one 18650 from 1/more 18650s.
I’d just get one of those Tomo(?) packs which double as chargers, and just pop out one of the 18650s in there to use.
Or just keep spare charged cells floating around. 80% is plenty for longevity and good capacity.
Me, unless it’s done right (eg, F1), I don’t really like built-in usb charging. One more weak-link for water/dust ingress. Mentioned my fave toy, the RJ02, has onboard charging but the rubber plug somehow pulled out. So I just don’t use it in the rain or anything like that.
Then again, I got like 4-5 spares, all with intact plugs, but… :smiley:
I don’t think it’s one or the other. You can have usb charging, as well as the ability to change the internal battery if you want.
I don’t think I’d want a light with a proprietary battery that could only be charged with usb. But a regular battery, that you can easily top up with usb before heading out, is handy.
The downside is usually loss of water-proof. But most of my lights never even see rain, much less the bottom of a lake.
You’re right, it’s a bit lazy to not want to switch batteries. But, hey, so is pressing a button to turn night into day! :wink:
Aren’t there some cells with micro-USB ports built-in the protection circuit? At least Nitecore and Soshine I know have them now. This should be a nice compromise for keeping the flashlight water resistant and reducing the need for a dedicated charger in the backpack if the goal is to reduce bulk.
Lumintop has them as well.
I carry three most of the time. C8 and X2R and Hugsby P32 which is double AA :)
It was only a thought from discussion starter that C8 would be best budget thrower with USB charging feature. It is in my opinion best even without that. Just what somebody said, no unnecessary holes in body to water or dust. Other light marks have nothing to do with this opinion. And again, just my opinion :slight_smile:
Hi all,
I would like to ask a silly question….
I have ordered a convoy c8 from gear best, but I can’t figure out how to get the driver out…
I have removed the led, but this seems to sit on a shelf, so does not help in getting the driver out, which seems to have to come out the tube end…
Is that thing with the 2 small holes in the retaining ring? I have tried to insert something into the holes and turning it, but it won’t move….
Can someone help me out of my misery please? :confounded:
Hi Flitsmal! I drill those tiny holes bigger that nosepliers fit to holes. Be careful with drilling :slight_smile:
My poor and hardly used nearly abandoned Ultrafire C8 (still running the original XML) bought maybe 5-6 years ago got a new love today, a lighted tailcap :stuck_out_tongue: this will make My Convoy C8 jealous!
