can i drive a XM-L2 with a zener modded Nanjg 105c with 2 cells
The ground & out pins on the 7135 only see the difference in voltage between Vin and Vf. If you have a 100 volt supply, and a string of LEDs that needs 98 volts, the 7135 will only be seeing a 2 volt difference. The other pin, Vdd, must be kept at less than 6v, measured between the pin and battery ground. If you put too much voltage to the Vdd they will be unhappy and will either shut down completely or reduce their output (the likely cause of the low current in the single-mode version).
I’m not sure which (of the many… :_( ) scenarios in this thread you are referring to with that last parenthetical bit?
