@ProjectOne. Spent too much money on lights recently….but am very interested. So, I shared it on my Facebook just to try and help a little.
Edit: additional thought/question.
I see conflicting information. Your page says “Steel” or “Titanium” available, but when you click on the “Back this Project” button the choices are Aluminum and Titanium. Which is it? (I don’t want to be a naysayer, but that doesn’t instill confidence in a possible backer/supporter).
No, the charger from the S20R is a contact based charger. It has to make electrical contact with the light.
This lights uses induction charging, that means that it wont have to make an electrical connection with the charger.
(it induction charging even works when you lift the object off of the charger but only for the first 1mm or so.)
Yes, this is my msitake and I’ve noticed it too late ;( Can’t change anything in reward section.
Metal frame is either steel or titanium. Aluminium is too soft in such thickness. We’ve experimented with it and decided not to use.
Ok, thanks (actually, the light I have is the 15R, but it wasn’t clear if the charger was an contactless charger).
What about the modes question? Does/will this light have modes (and if so what are they)?
I just saw the comments on your project’s page. So only on/off, correct?
I also saw your response about no place for additional electronics, but modes are usually implemented in the software/firmware and not in hardware? Unless you are saying this light doesn’t have any MCU and is only direct-driving the emitters directly from the battery?
