Testing at longer distances (and installed in an actual light, if applicable) will be necessary to make a final determination about where the best focus is achieved and how thick a gasket should really be.
I am limited in the vertical distance at which I can test. I need to build a horizontal setup on an angle plate in order to test at long distances.
I think for most applications the G10 is the sweet spot. G12 and G15ā¦seems like they only added long term resistance to moisture absorption, and the fire retardant grades seem the same but much more expensive. I lucked out and got some scrap pieces of several to toy with (abrasives, though, not milling). I worked a bit with various soft plastics and three grades of GF nylon (I think 6, 11 and 30% if I remember right). Certainly nicer to work with although static cling is a major featureā¦all do make chips but those chips travel further than I would have expected while using a router and the cling wasā¦amazing. I think the 30% is whatās usually used in power tool housings, or thereabouts. There is some carbon-infused polypropylene thatās neat materal, tooā¦much stiffer and more dense than any of the GF nylons. With the G10ā¦yeah, all powder and it can be really irritating to the skin and mucous membranes, super bad news for the lungs, too (same for phenolic there). Iām not sure exactly why, but out of everything I toyed with it was the linen phenolic that was most impressive to me. Donāt see the linen version very much but itās really a different animal than the usual canvas, and both are quite different than the micarta/paper grades. The linen was (maybe still is) used as some kind of washer in oil drilling rigs, which I thought was interestingā¦not sure where exactly it was used.
