I have one, I used as a host for a low-wattage UV light build. They are a decent host as long as you aren’t running a high-power light. IIRC, plastic reflector and lens, but those are easily replaced. Lattice-Bright ultra-cool low-brightness emitter. The biggest drawback is the pill design. Although the light has a pill, it’s a drop-in design with a threaded ring to hold it in place. The pill does not actively engage with the body in any way to help transfer heat into the body.
