Yes and no - for example, the lume1 driver has MISO and MOSI around the wrong way so you’d need to break out the cable to swap them. I’m perfectly happy to build a custom cable to do so if I need to, as long as the pad spacing is correct.
I can’t remember if it also needs to be an attiny MCU because it’s early and my brain hasn’t fully started yet
This is a sad day that this GB is closed… I tried putting my CULPM1 in my ft03 but I don’t have a large enough diameter mcpcb (I was using a 20mm, really need ~30mm)…
