The advantage of the SBT90.2 is the actual emitting area is much smaller than the XHP70.2 resulting in greater candelas per lumen. That’s great for a high-power thrower, but I agree that the price makes it a bit of a niche part.
I would be much more interested in seeing SBT90.2 in the M26C or L21A. I really want a thrower with that emitter than isn’t super heavy and large like the K30GT or larger searchlights, and isn’t crap quality like the FT03S.
The 4x18 has some weight in it, might have even better thermal dissipation than a L2/L21A
But it does not need thermal stepdown at 55 DegC, better to use a programmeable driver, anduril would be nice…
The 4x18A isn’t a budget light (or what I consider one) at $60, and adding a SBT90 plus a driver revision and whatever else would be needed (changing battery configuration) would add even more cost. Its doable, and would be a probably low demand item. I guess it’s up to Simon whether to tackle it. Would be interesting to see how cheap he could sell it since the Convoy lights are in my opinion some of the best for the money currently.
In theory, the FET+ driver would be cheaper than a boost driver, but the LED, of course, is a big additional cost. XHP70.2 lights are common, been around for years now, but there isn't a properly powered (i.e. 4 parallel batts) SBT90.2 thrower around in this size.
I think you could mod the 4x18 with a driver, emitter, and change the battery configuration yourself to get it to run the SBT. That would be chore to get the series to parallel in that thing without a dedicated battery carrier. Maybe Simon could talk a manufacturer into making a 4S body and swap in a commercially available driver and led? Anything is possible in China it seems if you know the right people!
Hum, it says “1–10–35–100” and will probably have memory (they normally do…).
Would be nice if it didn’t have memory Simon or at least if it was configurable
Yep, the batteries are all properly set up for a SBT90.2 - parallel.Could even make a triple, like the old SolarStorm/FandyFire SP03. Originated back in 2013, but again, a nice quad cell soda can base. I got one running a FET+1 with triple SST-40's, ~8000 lumens, ~260 kcd.
Always wanted a big triple head for a Q8, but closer to 100 mm width, equal to the old Shocker that basically had 3 C8 size reflectors.
