Simon, is this also your store?
Convoy Direct Store
2.26€ |Taschenlampe taille clip, edelstahl clip, für neue C8,M2,S3|s3...
Smarter Shopping, Better Living! Aliexpress.com
With all due respect, I wouldn't call that a “FET driver”, as generally speaking when people says FET driver what they usually refer to are unregulated MOSFET drivers (which is nearly like “no driver”).
That driver does not have an average 98% efficiency. The efficiency of such driver is directly and very easily calculable: Vled / Vbat, quite simple because current is constant. See this and you will understand: Electrical Efficiency @ Wikipedia
When the battery is depleted and its voltage is very close to the effective led Vf (which will also be quite low because of the low current drive in these circumstances) then and only then the efficiency will be very high.
I would call these linear drivers, as they burn any excess voltage in order to maintain a constant load current.
Yup, that sounds right, Barkuti. This is an Op-Amp + FET linear current regulator. It’ll be efficient when the battery and LED VF are close. But with a full battery, the difference gets “burnt off” just like with an AMC7135 or similar.
Convoy Direct Store
Totally looks like someone else's store.
This is what happens out there when they can't figure out how to be successful by themselves, they blatantly copy someone else's motto.
Simon Mao: caramba:…
Is the 8A driver the one with the unusual Ramping mode? 17mm / 22mm driver for luminus sst40 LED
not this FET driver.
it’s constant current with high efficiency (98% or so) ,With all due respect, I wouldn’t call that a “FET driver”, as generally speaking when people says FET driver what they usually refer to are unregulated MOSFET drivers (which is nearly like “no driver”).
I may be mistaken, but I believe his comment about the efficiency was in reference to his new driver which is not yet available on the store.
guys is there a data table of convoy flashlights like the zebra light one
already have s2+ and c8 as a reference point, would like to compare models short of buying each one to figure it out
New driver? That's grrreat. However, 98% efficiency? That's a very bold statement. I do not mean to say it is impossible, in fact I believe that everything's possible. However I don't take things lightly, and to me honesty and trustworthyness matter. For this reason I often find (chinese) advertisement claims ridiculous.
Hi Simon,
Can you enable “AliExpress Direct” shipping on your store ?
which country?
Simon Mao:What about this one S21B (S11 21700 version)
When roughly expected to be available?
tomorrow
Yokiamy: Simon Mao: Yokiamy: Simon Mao:4040 DTP board and gasket are in production now
AWESOME!
Can’t wait!
Do you have an alternative 22mm driver which is able to deliver 7,5 A?
There will be 22mm driver with 8A current available
Please keep us posted!
That sounds like a perfect combo for the L21A !
This does sound like a killer combination.
Thank you for working on these Simon. We appreciate it. Any estimate on when the gaskets, board, and driver might be available? Thanks.
4040 gasket and board will be available in this week
driver will be available after 2-3 weeks
Convoy Direct Store
i have only one store:
https://convoy.aliexpress.com/
caramba, yes it is. “Adjustable” would also be a good moniker for it, imho.
It’s actual current output is slightly below 8A.
Thank you for clarifying
caramba: Simon Mao:There will be 22mm driver with 8A current available
I am definitely interested in this killer L21A . :partying_face:
I will produce some holsters suitable for L21A in small quantities
And please reserve me some holsters for L21A / L2.
Or should I just drill a hole on the bottom of a M26A / M3holster.?
n
ZILZAL:Hi Simon,
Can you enable "AliExpress Direct" shipping on your store ?
which country?
Saudi Arabia & UAE
Simon Mao: caramba: Simon Mao:There will be 22mm driver with 8A current available
it’s constant current with high efficiency (98% or so) ,I am definitely interested in this killer L21A . :partying_face:
Simon Mao:I will produce some holsters suitable for L21A in small quantities
n
I will keep a bottom hole in the holster, and I want the holster to be slung on the back waist instead of the side waist.
Simon Mao: ZILZAL:Hi Simon,
Can you enable “AliExpress Direct” shipping on your store ?which country?
Saudi Arabia & UAE
I have successfully operated in the background, but it will take 2 days to take effect.
@Simon
With S21A in hand and S21B coming out, the only thing that comes to my mind is CLIP. Do you have any plans for making clips for these boys?
PS yes i am a deep pocket carry clip person, no matter what size of the light is...
PS yes i am a deep pocket carry clip person, no matter what size of the light is…
My metal clips can be installed on them, but they will leave scratches.
I presume you are talking about screw on clip but i had i mind S2/S2+ clip
id30209:With S21A in hand and S21B coming out, the only thing that comes to my mind is CLIP. Do you have any plans for making clips for these boys?
Which metal clip Simon ?
This clip?
anyway, is this clip also suitable for S2+ ? It only mentions “… for new C8,M2,S3”
