Hey Barkuti, no problem, it’s always good to hear your 2 cents.
Don’t know, maybe warm white is better. Maybe red… :nerd_face:
I’ve decided to start with yellow since I remember some cars use yellow anti-fog lights. Warm white is typical for old-fashioned bulb lights and for some reason somebody decided yellow will suit better.
But it may also be some other color/wavelength is better (e.g. green or red) but not commonly used due to interference with colors meaning.
Well, first I’m gonna build the light, then we’ll see if any difference can be spotted.
I would be happy with that as well
My wallet won’t, since i need to buy three new (matching) cells which i need to hold together.
Plenty of 18650’s though
Will the 4x18650 version require to use button top batteries? If so, I will look forward even more to seeing the 3x21700 version.
Why? Because a) button top batteries are harder to get and b) button top batteries often add significantly more contact resistance, especially those with cheap joint-welded buttons that tend to rust quickly.
My hopes are that these new lights have a different battery compartment with brass buttons on the positive poles of the head unit instead of a brass ring (which requires buttons on the batteries).
You mention, that driver has 4.8A current, but for this CSLMN1 specific tint (.FY), only between 2.5-3A is recommended. Above 3A, output flats out, and at ~5A, output is even less, than at ~3A - this means, efficiency drops very fast.
I think all the yellow CSLMN1 variant has the same specs as the white variant in paper. The white version output peaks at 4.5A-5.0A according to a test and 5.75A according to another.
I can’t find any test for the yellow variant, do you have one? The datasheet only shows data for up to 3A as for the white version.
I have the Noctigon K1 fitted with the specific variant, CSLMN1.FY, and my K1 has even less output at 5A, than around 3A. So you can trust me.
Also, you should look for CSLMN1 specifications for other tints, and you will need to compare If (forward current) vs. lumen output graph carefully for each of them, and then, you will see, that for the Yellow and the True Green variant, output starts to flat out much sooner, than for other variants. Also, those graphs are probably for a close-to-perfect soldering work, which will usually not happen. So, for less-than-ideal situations, that output will flat out even sooner - this is why we need to examine each kind of emitters (or at least make use of the graphs as well in the specification, no just the basic stats), and choose safe driving current accordingly.
Hank stated to me the K1 drivers are not being tweaked per LED type (at least the white W1 is the same as the green W1), so this is not surprising. Each of these color specific W1's have their own output curve with a different peak current, and Hanks and Simon are not properly configuring their drivers accordingly. Of course the other variant is the quality of the LED reflow, also assuming it's on a known good 3030 MCPCB of course.
At least with the K1 you can swap a resistor to control the amp output - maybe can do the same with Simon's driver.
