Thanks for the info. The smooth or OP reflector doesn’t make any difference to the beam angle, just the hotspot. Pretty sure the L6 (I sold my original, one of the first L6 made) had a wider beam angle, but the L6 is too big for my needs. Likewise, the S11 which would likely have a much wider beam angle, probably doesn’t have anywhere near the output or heat handling. An M21 with shallower reflector would be a great match for 7070 emitters such as the GT-FC40 and XHP70.2.
I've never heard of LED's running any cooler than others, given the same wattage (amps x voltage). So the LED that runs those 8 amps at a lower voltage would be cooler, but the difference won't be much.
Here from the djozz test, the SFT-40 at 8 amps does about 3.45 volts. I can't find a test of the CULPM1.TG (Boost HX), it may be here somewhere, but not sure where. From the datasheet on the Boost HX here, it looks like 8 amps does about 3.45 volts, looking at the Forward Current diagram.
So djozz's test of the SFT40 compared to the datasheet on the Boost HX shows about equal voltage at 8 amps, therefore the wattage is the same, and therefore the heat produced should be about the same, assuming heat produced corresponds with the wattage. Both LED's are spec'd at 6 amps max as well.
If the larger footprint of the SFT-40 (5050) vs. the Boost HX (4040) results in more shedding of heat form the LED, then perhaps the SFT-40 has the advantage. In theory it should help, but it's not that much of a difference.
The thinking here is: total power consumed = light emitted + heat generated. If the LEDs really consume the same power, but the SFT40 is producing 33% more light, it stands to reason that there is less waste heat being generated. Now if someone wants to calculate how many watts the extra 500-600 lumens represents, we can assume that the Osram generates that same amount of extra heat compared to the SFT40.
I haven't seen it mentioned that higher bin LED's of the same type produce less heat. I wonder if anyone noticed or measured it. So for example a high bin SST-20 6500K truly produces less heat than a low bin SST-20 3000K at the same amps and voltage. Interesting if so.
Higher output as light in watts means lower output as heat but you can’t generalize that to lumens, because the luminous efficacy could be different. 600lm represents 1.5-2.4W, but the calculation only makes sense if the luminous efficacy of the generated light is almost the same for both LEDs, which would require very similar color temperature, tint and CRI. A greenish tint means higher efficacy while very warm or very cool light would intrinsically result in lower efficacy due to more red or blue and less green. 2.4W is less than 10% of the power that reaches the LED, so the effect shouldn’t be larger.
Edit: The whole article is extremely interesting. If using 100% efficiency light conversion the highest efficacy for a high CRI light source would be around the 3500-4300K range (Fig. 4). Also:
Just, WOW! It’d be a toss-up for me B/T Cslnm and Culpm, depending on preference of spot size as they seem to run neck and neck for throw intensity (at least from video view). What are your thoughts comparing them live?
You did a great job tuning those lights. Excellent vid.
