Ooooo! Looking forward to it.
Yeah, I don’t think you realize what ring I’m talking about there matey. That which you have linked is caused from the AR coating on the glass, this isn’t an issue in the slightest.
Here’s what I’m talking about.
Yes, I 100% agree that it’s not always the case, this is why I said that
There’s quite a few Convoy and non Convoy models I’ve reviewed that don’t have an SS bezel and still have rings, but…, none have an outer ring as bright, and as noticeable, as those with an SS bezel and it being the cause. Rings in general aren’t my issue, it’s ones like the M21G that I can’t stand to look at.
S21E XHP50.3 HI
XHP50.3 HI R9050
XHP70.3 HI R9050
S21A XHP50.3 HI
S21A XHP50.3 HI with battery
S21B XHP50.3 HI
S21B XHP50.3 HI with battery
M21F When will it be available with xhp70.3 hi cri?
Edit: I’ve just ordered the S21E XHP50.3 HI R9050 5000k. I’ll post the review as soon as it is complete.
I bought the M21F before 70.3 was even an option so it came with 70.2. I swapped in a 70.3 HI. Now it seems it’s gonna get another emitter upgrade LMAO.
Simon, could you please share the CRI, CCT and DUV measurements of the 50.3 HI 5000K 90CRI at the 35% mode?
My S2+ actually had both rings.
So do mine, but they aren’t what I’m talking about here, the headlamps and M21G are very, very bright.
I have the T2, T4, H2, H3, S2, S2+, S21E, S21F, M2, M21D, M21E, M21F, M21G, C8+ L21A, L21B and only the H2, H3, M21C/G (same head) have it so bad that it’s something that bugs me on turbo.
If i remember correctly @id30209,(in the M21c xhp70.2 review thread by @Bilakos10)fix his M21c 'ringy thing by coloring black the inner lip of the bottom hole of the reflector ,the 1mm portion that surrounds the emmiters dome.
Perhaps Simon can address this M21c,d,g series 'ring artifacts in near future by tweaking the design of the reflector of these wonderful series mid-size flashlight.
All 70.3 are the lowest flux available, so tint will probably be good. 50.3 can be a little above BBL, at least the 5000K. We will be sure when Simon share the tests.
Will there be a H series headlight?
How does the XHP70.3 HI compare to the GT FC40 in the M21E?
Personally I don’t like the FC40. I find them a bit green. Even the 3000k CCT. I recently bought all CCTs of the 70.3 hi. Although “low CRI”, they have just a sweet tint. It’s gorgeous. Specially the 4000 and 3000k. A bit rosy.
Hmm, interesting. I have a 4500k FC40 that is probably one of my favorite tinted lights next to my domed 519a. I like perfectly neutral lights and get uneasy when things get as rosy as 219b.
Any idea how they compare in output/throw?
Tint is a very subjective thing. I do prefer the more rosy kind. Having said that, I don’t have a 4500k FC40. I’ve tried the 5000-5500 and the 3000-3200k one. Wasn’t really happy with neither. I think I’ll get the 1800-2000k one next just out of curiosity. In the 4500k range I have plenty 219b’s and for a more neutral experience I have the B35AM.
Output I don’t really know because I don’t have equipment to test. However in the throw department I have almost certainty that the 70.3 HI will outperform the Fc40 due to die size. The 70.3 HI has a much smaller die.
