Definitely 21700, I don’t even own any 18650 flashlights or batteries. I prefer the long runtime and don’t mind the extra weight.
What a pity ! I was just going to order from Germany.
As I live in Germany, if there is anything I could help you here, let me know !!
Thank you ,Maybe this month my WEEE number will be registered.
ok ,I can make changes in S21D,
Fantastic! Looking forward to seeing it!
Nice one Simon! When will you put that into production? Eager to test out the 719A in the S21E host.
ok ,i will produce a 2.2A driver for S21E with 719A or B35AM
According to the item description of the S12 host, the reflector is 28.6mm diameter by 11.1mm height.
will you find suitable TIR lens for S12?
One more to the list.
Simon, can the B35AM use 3535 TIRs?
That looks sweet! Will you be offering the S2+ with the boost driver and B35AM installed?
What flashlights can fit this driver?
It’s 17mm so it should fit(unless it’s taller than it appears) S2/S2+/S3/S6/S8/S15/C8/C8+
Edit: With an adapter any 20mm or 22mm mechanical switch host should also work.
Also M1/M2, I think.
I knew i was forgetting some!
Thanks!
B35AM 3.65*3.65mm size, you can use 5050 TIR
yes,i will add a link when it’s available
I am just going to wait for Simon to make a 6V 2.2A driver for the S21E and then add it to the cart…
