The original FX30 driver (not Convoy’s version) used an R100 and R082 side by side in parallel creating .045 ohm of resistance which supposedly produced 4.5 amps on its highest setting.
Convoy’s version of the FX30 driver uses a pair of R082 resistors creating .041 ohm of resistance. This produced about 5.25 amp on its highest setting.
Now if we take the 2 R082’s (Convoy version) and add an:
R750 we get - .0388 total
R500 - .0378
R250 - .0352
R140 - .0317 = 6.3 amp from DBCustom
R120 - .0305 = 6.34 amp from Vesture
R100 - .0290 = 7-7.3 amps From TexasAce
From all the information I’ve found, a adding the R100 is about the limit the driver can handle. It’s about the same as a direct wire and you get 7-7.3 amps. Some folks have smelt a little burning, but it still worked.
To get past 7 amp you need a replacement driver. Some have done 9 amp, but the heat caused the output to drop quickly after 20 to 30 seconds. Here’s a handy chart.
I got such an effect, not very interesting and satisfying Link to screen
Any suggestion ?
In plans i’ve de dome and boost driver to ~7A.
De dome only will help ?
De-doming is the best thing I know of to close up the dark spot in the center when using the SMO with this light. It will not be perfect on a wall close up, but outside the beam is pretty good.
I’m know that, only just want to show effect on short distance to wall - can see the black hole in middle.
Thanks for answer, on my country lights forum one of the users offered me to exchange diode on XHP70.2 - supposedly it works with the SMO reflector and it can be better focused on the XHP70, but in this moment haven’t to much money for this ….
The beginning of the season for two wheels is approaching, oil changes, filters etc.
Thanks all for comments, will try to make corrections in the form of a de dome and increase the controller’s power, we will see if I will get a satisfactory result.
Please verify your light has xhp70/70.2 and the driver is 30mm.
This would be the driver from Convoys AliExpress store.
US $6.24 | FX-30 driver for CREE XHP70 led
