【convoy】M21H bezel available now
There is no reason to want a COB in a flashlight, for all possible purposes a powerled makes more sense, even when pure flood is the goal. (there was a thread about it)
Yeh, my Cometa has that. Called “medium-press”, oddly enough. Dunno what “long-press” would be, then.
Thanks for paying attention, djozz.
Still, I feel curious with respect to taking a nice look at the performace and output of these.
Interestingly the LumeCube 2.0 uses a COB for a very smooth floody beam.
Asked maukka about making some sunlight spectrum CoB led review. Guess he will say something in a while.
I understand they may not break any luminous intensity record. However, with a decent sized reflector they will still be suitable for short range lighting, at the very least.
I asked four of the sunlight spectrum 1414 COBs for review.
1700K https://www.aliexpress.com/item/4000785096259.html
3000K https://www.aliexpress.com/item/4000784938078.html
4000K https://www.aliexpress.com/item/33041200634.html
5000K https://www.aliexpress.com/item/32957085202.html
C8+ with KR CSLNM1.23
output current 2.5A
Simon, can I have S21B with CULPM1.TG and 12 groups 6A driver? How to order it?
Hi Simon, I am very interested in flashlights using monochromatic light, e.g. your new C8+ using Osram's KR CSLNM1.23. Did you measure the output in lumen yet? I wonder if 2.5A is its sweet spot already or if it can safely be driven beyond 3A with signicantly more output.
For comparison:
I have bought the Amutorch New VG10 from Neal Zhang. It's fitted with Osram's Ostar Projection Compact LE Q8WP. It has 3 modes only (Low-Medium-High). For the naked eye, there's barely any difference to see between Medium and High mode. But on High mode the lights draws 5A from the battery. The head unit gets fairly hot within a few minutes.
i create a special link
I think there is no problem at all to increase the current to 3A. The mode of my driver sample is 30–100, but visually the brightness difference between the two modes is very small. I consider only providing one mode 100% or two modes 10–100. I don’t know about hunting. I would like to know if 10% mode is useful for hunting. Or is a 100% mode sufficient for hunting?
Just hurry up with grey so i can add this to the cart :)
Personally, I would favor following forward clicky setting for a red/green light thrower.
Hold 2s from OFF: 0.01% = Firefly mode
Tap #1: 20% = Low
Tap #2: 100% = High (should ideally be stable in output, using a constant current driver)
No strobe, no SOS, no beacon
4x quick tapping: Change mode order (Low-High <> High-Low)
I cannot buy it: “Sorry, this item is no longer available!”
You need a reylight driver :slight_smile:
Yes this would be almost perfect.
100% mode is NOT sufficient for hunting. Having a LOW is important.
I wonder if there is a visible difference between 10-20-30% as Simon mentioned.
SOS: I personally find hidden RED Strobe or SOS or beacon, quite useful.
Our car always breaks down in the wrong place and using a RED flashlight blinky instead of the car blinkies preserves the car battery . Of course it could be Hidden but very useful. on the other hand WHITE strobe is annoying.
Wait… what were we talking about again? Existing light like a C8+ or a fictitious maybe-light?
existing C8+
basicaly a C8+ host with a RED or GREEN OSRAM,
L21A would be good candidate too.
Saw this yesterday. Thanks.
Did the seller said anything?
Monochromatic red is useful for hunting, but what about green? I guess it's not for a traffic light, LoL!
For photographers 10 to 100% is too big a step. I prefer the second mode to be at the point at which the light can run without getting excessively hot.
