Barkuti
(Barkuti)
September 28, 2020, 5:28pm
3481
Simon Mao , I think you need a bit of help here. If you want your flashlights to satisfy all your customers, you must bear in mind your flashlights need to fit the entire range of available cells they are supposed to fit.
You just cannot presume your customers are going to use “only this or that battery”, this is wrong my dear. In one way or another many of your customers are buying cells from reputable chinese OEMs like Far East Battery (example ), or Lishen . Once rewrapped by 3rd parties the cells from these manufacturers measure up to ∅21.7mm . Play it safe, add an extra 0.5% or 1% to that figure and make sure the 21700 tubes of your flashlights are bored (drilled) to at least ∅21.8mm or ∅21.9mm. If your flashlights can accept all sorts of 21700 cells everyone will be satisfied, diameter or tube bore is paramount in this regard.
id30209
(id30209)
September 28, 2020, 5:25pm
3482
All my 21700 Convoy’s have extra space with cell installed (Molicel and Samsung).
S21A, M21C and S12
Yokiamy
(Yokiamy)
September 28, 2020, 7:47pm
3483
d_t_a:
Orbik:
Hi there, just bought Convoy M21A with KW CSLPM1.TG led and now realising maybe I went wrong with the batteries… I got 2 different vapcells 21.5 * 70.8mm and 21.1*70.5mm sizes… And since I also want to buy upcoming L21a,culpm1.tg light, my question is will these batteries fit? I read that all l21a-s are now coming with 22mm inner tube (altough aliexpress description about l21a states not to use rewrapped cells eventough they should fit now, maybe they just havent updated info) but didnt find any info about m21a… So maybe Simon himself or someone else can clarify whats the tube size of m21a. Long story, but appreciate any help!
Interested also to find that information out before I purchase.
So far, I have tested these “21700”-using Convoy flashlights (but I got them much earlier, some are probably last year), and these are my results:
(I use Lii-40A 21700 around 21.7mm diameter for testing if it fits the 21700 body tube)
S21A = won’t fit Lii-40A
M21A = won’t fit Lii-40A
M21B = won’t fit Lii-40A
L21A = won’t fit Lii-40A
S12 = fits Lii-40A
M21C = fits Lii-40A
I haven’t tested these models (or newer batches of the above models): S21B
I have a few L21a’s
One it the first batch, which does not allow larger 21700 cells, the others a 2nd batch, which allows larger 21700’s
Simon_Mao
(Simon Mao)
September 29, 2020, 12:42am
3484
Barkuti:
uh ,inner diameter has been changed to 22mm ,It’s just that some styles sell slowly, it is still the first batch, the inner diameter is still 21.5mm
Barkuti
(Barkuti)
September 29, 2020, 2:14am
3485
… uh ,inner diameter has been changed to 22mm ,It’s just that some styles sell slowly, it is still the first batch, the inner diameter is still 21.5mm
Wise decision. :THUMBS-UP:
iRattle
(iRattle)
September 29, 2020, 10:31am
3486
Hello Simon.
Please advise if you are planing to update L6 or L21A using SBT90 diode and what price will be for both? I think many people will buy L6 with SBT90 for reasonable price 70-80 USD or L21A for 60-65 USD.
Tangra
(Tangra)
September 29, 2020, 1:28pm
3487
Barkuti:
What about length of the tube?
With new driver spring, length should be 4mm longer.
Otherwise springs does not work like springs.
Simon_Mao
(Simon Mao)
September 29, 2020, 2:25pm
3488
i’m ready to use 4X18A or 3X21700 host to install SBT90.2
JaredM
(JaredM)
September 29, 2020, 7:03pm
3491
Looking forward to this. Should hit around 370kcd if driven hard.
Please, 3 x 21700 using flat top batteries. 21700 cells will get more attention in terms of developing high drain cells.
iRattle
(iRattle)
September 29, 2020, 8:27pm
3493
3X21700 host will be great.
Mocarny
(Mocarny)
September 29, 2020, 9:55pm
3494
+1
Um…btw, I just posted the Z1 review, so you can check it
Convoy Z1 - Convoy's first zoom flashlight (well, it was clickbait, actually the second one)
3 in 1 review. At the end there will be a summary for those who like only particulars, in each topic I will bold the key sentences for those who read a little more, and a long waffling for everyone else. Enjoy!
[image]
For VERY large photos: click -> on the photo page right click -> "Open image in new tab"
Table of Contents:
-General parameters
- Package content
- Appearance, parameters …
oweban
(oweban)
September 29, 2020, 10:02pm
3495
The only issue with using flat top cells in a 3x21700 light is that inherently those designs have a “ring” for the driver (see: SP36, Q8, MS06 etc) - it’d need an adapter like the one in the 4x18A with brass slugs to work. I’m all for that though! (I still want to buy that adapter by itself……)
Simon_Mao
(Simon Mao)
September 30, 2020, 1:10am
3496
oweban:
Dont worry ,i have adapter for 3*21700, too
JaredM
(JaredM)
September 30, 2020, 3:11am
3498
High drain cells won’t be necessary with a single 90.2 in this light. Turbo would only be about a 2C discharge rate
Thank you, the idea of some triple 21700’s is encouraging. A Convoy 4X18A or 3X21A flashlight gives a few great LED options like Luminus SBT-90 or triples.
Awesome! There are only few 21700 button top cells on the market, mostly proprietary batteries with a PCB from Imalent, Klarus, Acebeam etc.. These batteries are very expensive, though. So, let's please stick with support for standard 21700 cells that are flat top or even with a recessed top (see "Tesla" batteries sold by Vapcell). Thanks for the great work, Simon!
