Those were shone on the ceiling (it’s white), from about 6-8 feet away. It wasn’t really to show a beam profile, just the tint differences. But it is funny to see how horrible the beam profile from a four D-cell incandescent maglite is, though. Funny how I used to think it was okay, back when that was the norm.
Not trying to bash or anything but i am used on better fit and finish from Convoy. After all i have 13 Convoy lights at the moment and none of the lights (while they where in stock form) failed me. This is not a big deal for me but hey it could be better.
This is the desert tan version bought directly from the Convoy Aliexpress store.
Not sure about the metal button, but on some lights the switch retaining ring is reverse-threaded. Try checking both ways in case the button assembly is reversed.
It probably isn’t, but it’s at least something to try on sticky parts.
I’m going to disagree with the characterization of 3A as a preferred tint for snobs. my understanding is that 3C (aka below the Black body line) avoids the cat piss green better then 3A and is (or was) the preferred tint. The larger trend is I believe that 4C is fast becoming the preferred tint for non Nichia snob applications.
It’s not always guaranteed that a “good” A/D tint bin will give you good results. Here’s an example from an Olight S10R III with Luminus SST-40 emitter. Judging by the total average tint, it falls near the 1C/1D border at 0,3176x 0,3347y, but in actuality the result is something totally different: warmer much greener and with a horrible shift to cool purple on the spill. Of course the manufacturer reports the bin with a bare led integrated rather than with a reflector.
Yeah, that looks pretty extreme. I’ve noticed that the purple spill is a problem in most of my cool-white lights. (Another reason I favor neutral white.)
Well I certainly cherry picked the example. It’s the worst I’ve come across. Still, the difference between integrated tint and hotspot is significant. Here’s a comparison between the S10R III and a S1R. The spill is truly purple on the S10R III.
It’s no coincidence that an Olight S10 lens is the one I use to demonstrate the downsides of AR coating. Here’s an Olight S10 AR-coated lens next to a plain piece of glass:
I put a 3D tint emitter into it, and the result was the ugliest green I’ve ever seen in a flashlight. It also had a pronounced blue/purple ring around the outer edge of the spill.
By simply swapping in the plain glass, the beam became dramatically better.
Optics can seriously mess with tint, in much the same way that a prism can turn sunlight into a rainbow.
I think it must depend on the quality of the coating. For example, none of my camera lens filters (such as the clear protection filters) show any color shifts. Photographers wouldn’t put up with that.
Yes, not all AR coating does this. Olight’s was just particularly bad.
I’m not sure, but I think they may have fixed it since then. And on their newer S-series lights, it’s not an issue because there is no glass at all — just a bare plastic optic. The optic still shows a bit of Cree rainbow, but it’s nowhere near as bad as it was on older models.
Regardless, I’m mostly just agreeing with maukka. The emitter itself is only part of the equation. Other factors affect tint too.
