The one that doesn’t heat up as fast will eventually end up hotter though, because with a badly cooled LED the efficiency is lower and afterall the heat has only one way to go: to the flashlight body.
For that to happen it’ll have to exceed some 180°C
Between what and what?
Adding a layer with a sticky glue backside doesn’t help.
It will be worse than PCB directly on pill.
You can increase the pressure by screwing the pill tighter into the head.
A thin layer of thermal grease will increase the surface contact area.
Not capable of reflowing led’s I ordered a 5050 size Epileds UV led on a 16mm aluminum board for my 8*7135 Convoy S2+. A bit of paste under the board and clean threads on the pill. That’s all. When I heard there was some doubt about the lifespan of this led at 2.8A, I put it up to the test. Being rather wordy I’ll fast-forward to the result. On several occasions I have fired up this light at maximum power, tailstanding on a low table in my livingroom. And left it on, until I got a low voltage warning. It got quite hot at 2.72A … but let’s call it bearable. No smoke, no smell.
Don’t have any scientific data for ya. I was goin on my own experience of the smell coming from my jacket pocket when mine accidentaly came on at turbo for a bit. :person_facepalming:
Sorry i should have been more clear.
Between threads to increase thermal conductivity of the surfaces there.
Tape as in thin strips, not sticky ones. I’ve got some that was left over from high voltage (12kV) termination kits and it doesn’t have adhesives. Just super thin copper. I’ve used it between theaded components before and it seemed to help, didn’t run any tests as i was happy the threads weren’t as sloppy anymore (wasn’t on a flashlight) hence the question mark. I’m new to flashlight modding, so just offering suggestions and personal experience. Keep me lined out friend :+1:
Gotcha, the beam is what was scorching my fabric. Good to know how much a pocket can take though, (Dang, 180°C, pockets are tough lol) thanks!!!
Yep black microfleece!!
The copper (I’ll call it ribbon from now on :student: ) is handy. It also makes for pretty aesthetics when glued into the grooves of flashlight cooling fins. As you stated, I figure it hinders the cooling effect, used in that manner, to a small degree though.
Well, the grooves between the cooling fins of the average flashlight are often too narrow to have significant air circulation, especially when they’re deep grooves (or large fins).
It looks nice though.
Cooling blocks like in amplifiers have grooves you can stick your pinky finger in, for example.
About that ribbon, what’s the thickness?
I could use some for enhancing the thermal path between flashlight head and screw in pill.
I can probably find something on AliExpress or Ebay.
I’ve got two types, and comparing them to my feeler gauges one is about .04mm and the other around .08mm.
This is the closest i could find. All the ones i saw have adhesive, so the ribbon i have is probably made to whatever specs the termination kit company wanted. You could probably clean it off before use but the seller claims it is conductive adhesive.
2 pcs/ 5MM X30M Copper foil tape Adhesive copper tape Shield Tape Single Conductive Film COPPER FOIL TAPE Strap http://s.aliexpress.com/aaAveIr6?fromSns=Copy to Clipboard
(from AliExpress Android)
Nice to know the Convoy S2+ with 7135x8 can withstand continuous max power (~2.8A) until battery drains.
BTW, is that tailstanding test for a stock or modded one?
I’ve noted that Convoy (C8 or S2+) with 7135x8 XM-L2 seems to draw around 3.0A (tailcap current with my budget DMM) whereas the one using 7135x8 XP-L Hi seems to draw slightly lower current (2.8A). I wonder if it’s just due to the variance between Convoy flashlights or the XM-L2 is able to draw slightly more current than XP-L Hi? (I’m comparing different Convoy flashlights, not reflow different LEDs to the same flashlight, which I’m not capable of.)
Overall: it was a stock light I bought at GearBest. Just swapped the CW XM-L2 led for the UV led.
Details: put in bigger leads, bypassed springs and made sure everything was dry and clean, except under the led-board.
