I’ll measure it for you when I swap to the 3500K emitter, probably this weekend ![]()
I did not order the TIR from Simon but from the manufacturer directly - with shopping more expensive in the end, but I only noticed the shipping cost after I ordered ![]()
The ones Simon sell, show the hole being 5.7mm:
The other 5050 TIRs he sells have a 5mm × 5mm sorta stand at the bottom:
Mine are made like this, ordered from Yajiamei directly. I am pretty sure Simon uses them for most of his TIRs.
https://www.aliexpress.com/item/1416001235.html
They are nice since they need no gasket and can rest directly on the PCB.
Ok, it confirms I got sent the wrong size. Mine are slightly less than 4mm so definitely 3535.
My latest Convoy order showed up today. A red S2+ 18350 with SST-20 deep red, as well as an orange S2+ 18350 host. I put a 3V 5A buck driver and a FFL351A 1800K emitter in the orange host. Both red and orange were swapped to 20° beaded TIRs.
Soldering wires to a MCPCB with lead-free solder is a pain btw. The joints got so ugly ![]()
Reflowing emitters on with lead-free paste however works really well.
Very happy with my growing Convoy collection ![]()
If you want to fit in a square object of 3.5mm X 3.5mm, you need a round hole of 4.95 mm.
If you want to fit in a square object of 5.0mm X 5.0mm, you need a round hole of 7.07 mm.
I think this is a big miss lighted color switches not working on the color hosts and or not having the option for rubber switches
If it has a silver metal button you can use the illuminated tailcaps but it’s not super visible:
