My green lighted switches run at around 0.07mA (5.7 years on a 3500mAh battery) and blues at 0.15mA (2.6 years). Plenty bright under clear silicone switch boots.
The green 0805 SMD LEDs are by far the most efficient of the available colors.
My criteria is that I need to get a year or more run time with my lighted tail switches, given the color/battery combination.
What lit tailcap do you use, self made, modified, or say one of led4power’s ILCs ? And were any mods such as bleeder resistor required?
(I’m interested in one for a Jaxman E2L, for me same requirement: 1 year minimum runtime not using the main LED, low voltage protection would be nice but at 1 year not that essential)
Keep in mind too that different drivers respond differently to lighted tailcaps. I need to use more resistance for the same amount of brightness with a Mountain Electronics MTN-DDm driver than with a Convoy SST40 driver.
And people have different preferences on how bright they want them to be.
But if you like modding your flashlights, lighted tailcaps is a fun (and sometimes challenging) sidebar!
The rubber boot requires this black plastic “spacer”? Not sure exactly whats its called, but since its not clear, it completely blocks the light from being visable at all.
EDIT: Nevermind, I just seen the lighted switch comes with a clear version of the plastic ring.
Interesting to see how a frosted TIR optic smooths out the beam.
Upper is Emisar E21a 4500k with clear optic, lower is same Emisar with frosted optic.
(The 219b light has clear optic in both pics.)
You are going to get me in trouble answering this question. :innocent: There are a lot of passionate fans on either side of these 2 brands. I actually have more Emisar D4V2’s than Convoy S21D because Emisar offers 219b in multiple CCT choices, whereas Convoy only offers the most famous and popular one, 219b 4500k. Some considerations strictly IMHO-YMMV
Emisar D4V2: IMHO a “prettier” light than Convoy, with beautifully-done knurling and multiple colors and metal available (although the brass and copper versions are very heavy, almost too heavy). Smaller and fit very nicely in the hand. Battery 18650 so lower capacity. If you get this light don’t get the option of raised ring around the button (I really dislike it in use) unless you really need it to prevent accidental activation. D4V2 has Anduril UI which I much prefer to Convoy UI. Set at 55 max temp the central hotpot is brighter than Convoy at Turbo start, but after a couple minutes, step-downs occur and brightness begins falling behind Convoy and the beam covers a smaller area. I think this is due to the smaller thermal mass of the Emisar. Convoy S21D: Bigger light & less expensive than Emisar. Does not look as nice as Emisar to my eyes but at 30 bucks I’m not complaining. 21700 battery a plus. The beam covers more area and stays brighter longer.
If I were to have just 1 light it would be Convoy S21D w/ Nichia 219b 4500k (aka sw45k) because of the 21700 battery and better brightness, but this is personal preference. Some people prefer D4V2 for reasons listed above. But why not get two lights: Convoy S21D 219b 4500k and Emisar D4V2 219b 3500k - this would be a great Nichia 219b start and IMHO 219b is a classic and will never become obsolete. Some examples of newer Nichia’s (E21a 4500k - very close but yellow greenish corona with clear optic, 519a 4500k - yellow tint; pictures and discussion previously in this thread) have not matched that legendary tint of 219b and I don’t think this will change.
I agree with Jon (who knows A LOT about different Nichia’s) that 219b 4500k is first light to get. Then add others, 219b 3500k, de-domed 519a, etc. as the hobby slips down the slippery slope and expands.
I think what Jon talked about (pls correct me as needed) is once you’ve de-domed 519a 4500k, the CCT goes down by around 1000, to 3500k, so the comparison should be de-domed 519a 4500k versus 219b 3500k. Then it is a matter of personal preference which one you like, not necessarily one is “better” than the other.
BTW personally I prefer 4500-5000k CCT not just in Nichia lights, but in all of my other lights. Higher CCT than 4500k then the beam color becomes too harshly bluish and depth flattens, lower CCT than 4500k then it gets too warm/yellow for my taste. The only exception is my super-thrower lights (Sofirn IF22a, the awesome Wurkkos TS30S, etc.), where for various reasons they are all higher CCT bluish.
I went way past my flashlight budget for the month BUT I’m willing to to grab a D4v2 in 3500k if the tint is really good lol
I currently have a S21D 219b/Pineapple-mini/Pineapple/T2 519a De-Domed/SC64LE/M150/LT1 Mini.
The S21D I really like overall except for the tailswitch/bulk….I’m sorta looking for a S21D with a Zebra size/switchUI, so I’m not sure if I should get the D4v2 in 4500k or 3500k
My fav tint so far is the Pineapple-Mini then the S21D, I would really like the 519a de-domed if it had more pinkness to it but unfortunately mine is more gold/yellow white
If you already have S21D with 219b 4500k then there is no question I would get the D4v2 with 219b 3500. There is no need to have two 219b 4500k lights imho.
Nichia 219b 3500 has a rich saturated tint that is very nice to look at. It actually is not too yellowish despite of the lower CCT and makes 229b 4500k feel a little too harsh and 519b 4500k a little greenish in back to back comparison.
I don’t have E21a 3500k so can’t comment. I do have E21a 4500k, and have compared it to 219b 4500k. But… whether 4500 versions translate to 3500 versions of these 2 LED’s, I do not know.
With white wall hunting E21a 4500 has a yellow greenish ring (see pic above) that 219b 4500 does not have. AFAIK this tint shift ring is why Hank uses frosted optic with E21a and clear optic with 219b. The frosted optic diffuses the ring and makes white-wall beam better looking, but then “hotspot” becomes a little too dim for my taste, and you could still see a hint of yellow tint shift. Having said that, in actual use, to my eyes E21a 4500 is very similar to 219b 4500 with frosted optic, but is greenish at periphery with clear optic.
At any rate for these reasons I do recommend 219b 4500k over E21a 4500 and see no reason to get E21a 4500 unless you see something that I have missed after SO much time wasted comparing :confounded: . Get the 219b 3500k, it’s a fantastic alternative to 219b 4500k. Very warm, very pleasant beam color. I love it and wouldn’t want to be without it.
BTW, Carlo Optics for Emisar D4V2 fanboys like me lol/JK. I replaced the frosted optic 10623 in my E21a 4500k with clear 10622 and liked the brighter hotspot much better. I also have 10621 but haven’t had time or a reason to try it yet.
Hank uses frosted optic in E21a 4500k for sure, but I do not know if he uses it for other E21a’s CCT’s. He puts some kind of grey gluee stuff around the legs so be careful not to smear it on the lens. The gluee stuff makes it hard to get the lens out; just use the tip of a needle to pry it out at the edge. And careful with the lens, it falls out and cracks very easily .
The optics are very inexpensive and fun to play with. I ordered it at the same time I ordered the lights from Hank to save on shipping and avoid the excruciating wait for toys from China.
