I have a couple of the new 17mm 5A drivers on the way. I’m planning a triple build or two. I wish Simon would make the same driver in a 3A version. For some LEDs 5A would be too much current. Since it’s single sided it’d be perfect for the S2+ without having to make a mess soldering a 7135x8 to the pill. That could render the 7135 based Biscotti driver obsolete.
Can anyone tell me- does this light, with xhp50 have the 3v or 6v LED?
It’s from simons store, the s21b with xhp50. The reason why I’m not sure is because the tint options are 3k, 4K, 5k, 6.5k… and I’ve never seen those options anywhere else with xhp50.
I want to try an osram in this, I already own it. Thanks
US $25.45 | Black convoy S21B with SST40 / XHP50.2 ,copper DTP/ ar-coated , Temperature protection,21700 flashlight,built-in 21700 battery
It uses the 2S or “6V” led. I call it 2S as it means “2 in series”, this is because XHP50.x (along with XHP70.x) emitters feature 4-dies usually arranged in 2 groups connected in series, each one consisting in 2 dies connected in parallel. With special boards the dies can be arranged 4S (4S1P) or “12V”, these boards are available from SinkPAD at some places like Mountain Electronics.
If you want to try an Osram buy an SST40 version. SST40 versions employ a ∅22mm, 6A maximum linear driver for 1S or “3V” leds: 4-modes or 12-groups. With up to 6A it is a very adequate driver for the CSLPM1.TG or CULPM1.TG, “2mm² white flat”, without going overboard with driving current, which in my lightful opinion is what happened with the new “8A single cell buck driver for CULPM1.TG”: it's somewhat overcooked.
Additionally, and concerning (XHP50.x/XHP70.x) 2S or 6V emitters, I can see the new drivers for XHP50/70 emitters (XHP50.x 12-groups, XHP50.x 4-modes, XHP70.x 4-modes and XHP70.x 12-groups) with pretty much “stock” driving currents. Considering the availability of more powerful drivers for 1S or 3V leds, I find this a bit underwhelming. Of course, this is just an opinion of someone always looking for an extra oomph. So, I recommend installing the XHP70.x boost drivers with/for XHP50.x emitters, i.e. if you buy an XHP50.2 S21B, you could give Simon a tip and ask him to put an XHP70.x driver in it (if he accepts, mind you). This of course is a call for more powerful boost drivers; XHP50.x and XHP70.x emitter tests prove they can handle twice the stock maximum driving current guaranteed. Some test examples: XHP70.2 P2 4000k Output test by Texas_Ace, early XHP70 test by djozz (up to 11.5A), XHP50 Output test by Texas_Ace and earlier XHP50 test by djozz (both maxed out at ≈9.25A).
You are asking for flexibility in deciding the maximum driving current. This is great, it could also save on modding work for people like me.
For this to be a new firmware is due. It could be based on the 12-groups “biscuit” firmware, for example by simplifying the group selection choices (less groups of modes), and reserving a few choices to set the maximum driving current:
Given the above 6 groups could still be reserved, and employ 6 group memories to set the maximum driving current at: 100%, 80%, 64%, 51.2%, 40.96% and 32.768%. Each one of these figures was obtained by multiplying the previous one by 0.8 (80%). In a max 6A driver this would set the list of driving currents as: 6A, 4.8A, 3.84A, 3.072A, 2.4576A and 1.96608A. This is with the full set of decimals, so here is a more simplified list: 6A, 4.8A, 3.84A, 3.07A, 2.46A and 1.97A.
This is just an idea. For it to be fruitful you need to “come to terms” with enough people, and of course the idea needs refinement (the group choices, for example).
Maybe that applies to the "AMC", but the ones we use today, and for the last few years, in Anduril, and I believe Narsil/M, we PWM 7135's at 16 Khz. It's been this way for years. Maybe we do it with some unnoticed issues? Dunno. Maukka tested here: https://budgetlightforum.com/t/-/52366/212
Tom E, I didn't say it cannot work. I just pinpointed to an article with related information.
And now that I carefully look at the oscilloscope screenshots in the article, doubts arise in me. If the figure up right in the screenshots is the time/div value, the frequency of the displayed signals is then a lot higher. First one reads 8µs as time/div value, and so the displayed signal seems to be of ≈20KHz; and for the second screenshot, with 4µs time/div, the PWM signal looks to be of ≈77KHz. :???:
But I am no oscilloscope expert, and I need to return to my duties. Hope someone can confirm if Pratik Panda put his foot in such review.
Wow, this is great information thank you Barkuti! I did not realize that the drivers being used fir the 2s xhp50 was so underpowered, and also never thought to request a driver change from Simon directly. I already own the s21b xhp50 6v, but may order another one with the xhp70 boost driver you mentioned. If Simon can swap it out for me that is. Thank you for this information!
“Underpowered…” Wellp, with these drivers they're being driven at their maximum datasheet driving currents. These are meant to provide some healthy minimum lifespan figures, which for general lighting is something important. In a flashlight lifespan is overall not so important, while actual sustainable driving currents are always obtained at lower modes. So, in practice with a powerful driver you can have both very high performance and long lifespan using a lower mode -after all, the heatsinking capacity of the flashlight imposes a hard limit on the mode current and power which you can effectively use continuously-.
P.S.: for very powerful 1S boost drivers the tailcap switch starts to matter. Springs too.
All good info, thanks Barkuti. and ggf31416 the halving of amps due to doubling of LED voltage is something i read before but forgot about. i agree - 6a and 9.8a are nothing to write off.
M3-C so as M21C-U have problematic ramp speed and FC40 is 12V.
It would be great if you could make XHP35 driver for M21C-U with only 4 groups but a little faster ramping than on M21C-U now (when steped groups are selected)
Simon has already told us that he’s planning a 3x21700 SBT90.2 version of the 4x18a. I suspect the L21a and/or L6 might get it eventually as well, since many will ask for it.
I do have a request for product improvement. I have two of the latest versions of the M2, and while they are great in so many ways, there are a few things I’d love to see in the future…
Supply ’pan head’ screws in place of the flat head type for clamping the mcpcb. The original setup forced the LED off center when tightened down and made it impossible to get a good beam. I swapped in some pan head screws and was finally able to clamp the board and have it centered at the same time.
Also, I’d love to see a forward clicky switch and maybe a rubber tactical grip ring for the light. The lack of knurling really makes it a slippery light, especially when combined with the deeply recessed switch that forces your thumb to bend tightly. I might be a minority here but I love the sharp knurling on the C8+ and would like to see more of it, as well as forward clicky options in these larger thrower/tactical lights. Maybe we get an M2+ ?
