Yes it would be a disappointment if it’s not quad 519a. And correct me as needed but I thought @Simon_Mao said triple B35AM is possible.
That experimen failed. B35AM without proper thermal pad and clustered close together started smoking way below normal drive current.
tbh not only the lights, but this photo is also very pinky.
I have temporarily modded mine with one. It is doable. Requires a gasket (standard butterfly 5050 works).
Which optic did you use? How does it compare to the 70.3 HI?
In case anyone is still puzzling over ConvoyLight.com showing a big “v”, I second the recommendation to reload the page.
This appears to be due to the page’s stylesheet not loading correctly the first time. The result is text and images don’t get scaled as intended, or laid out the way they were intended. Usually, pressing F5 or the refresh button to reload the page fixes it.
This is usually a fairly infrequent problem, but something about Simon’s page seems to be causing it fairly frequently. I see it on Opera, which is based on Chromium. I don’t recall seeing it recently in Firefox.
Sometimes that works, sometimes it doesn’t.
It’s still an issue that Simon needs to look into if he hasn’t already.
3 degree and Jarmay 3503. It was very intense, but not the nicest beam (forgot what was the issue). I may re-try it.
Thanks for the tip, I noticed this problem before and fixed it.
I should have added the 40pl option for all battery options.
If anything is missing, send me the link and I’ll keep adding.
Yes, the silver l6 flashlight is currently out of production.
Yes, I noticed this problem before I reported it to the website builder.
At present, it seems that this phenomenon no longer occurs.
The body of titanium alloy and the head of copper should be more reasonable.
OK, thank you. I just ordered two more of the black L6, and I can still use the different colored 26800 extensions to easily identify which light is which, so it’s not a big problem.
Hello, can you tell us when 14500 sideswitch and M21K/M29E will be available? Thanks!
Oh yes, i bee waiting for S21E and S21G in this combo for a long time now
I’ll take what I can get.
The problem just happened to me a few minutes ago.
Which bin is the added SFT25R 5000K?
@Simon_Mao Can you please add flux and tint bins to the SFT25R listing?
I would also like to know this @Simon_Mao
