I think it must will work. We just recalculate voltage divider for higher cutoff voltage. Direct connection to Vcc battery voltage is the best. Also if we want to protect LDO we can increase R1 value for higher voltage drop of it or install parralel of it 5Vzener for overvoltage protection but best will be to just use higher voltage LDO.
Thanks. I wonder a little what is the point of R1, because the VLDO regulator feeds the MCU and the Current Control Feedback Comparator -CCFC- stages. The MCU theoretically drains less than 1mA (46µA / MHz according to Renesas RL78/GU10 datasheet), and don't know about the CCFC but pretty sure quite low power too (< 10mA). When ā0.01A go across a 4.7⦠resistor the voltage drop is ā47mV, so what is the point I wonder.
You mean a 5.1V zener reverse polarized in parallel with pins 3 and 1 from the VLDO regulator. In this case, R1 would probably need to be recalculated (never done this zener stuff in my life LoL). Would be nice to know, we need to figure out the regulator's power consumption (current to MCU and CCFC), doesn't it? Or is it easier to find a higher input voltage VLDO regulator? No hurry for now, though.
I think it would be impossible for MCU to do the MP3431's job. The MCU could use ADC and PWM to make a switching converter, but performance and efficiency would be very limited.
Companies like Monolithic, TI, LT have all spent millions over the last 20+ years to make dedicated DC/DC ICs so highly optimised for power and efficiency.
And with the op-amp, you are right, the small-signal performance is far better than 10/12bit ADC as you mentioned.
The Attiny1634 has a built-in comparator, but it's not good enough for this feedback loop.
But that IS the topic :D . We need to understand the driver design positives and flaws if we want to improve it!
I'd say no. It depends on what you're mounting it in, but the top side ground ring is already very narrow.
I think I found a suitable SOT-23 linear regulator supporting higher than 6V input voltages, the Zetex ZMR330FTA.
But still not a word I've heard about the onboard stock one, can someone tell me which device it is? So we can know its pinout, maximum input voltage and etc.
The point of R1 is cloned from classic DEL and TA drivers. The R1C1 form RC filter which clean input voltage. Because we have heavy load with high input currents there is pulsating voltage from battery. Also 4.7 ohm is exactly the same used in TA drivers. Also C1 is decoupling capacitor for MCU.
This Zetex LDO is very good indeed. The max input voltage is 22V and also have very low self consumption like 40uA max. Just you need to compare if pinouts are the same as installed on PCB LDO for direct replacement.
Yes you can use any zener diode larger from 3.8V-5.1V. Is good to have enough voltage room for LDO to stabilize to 3.3V Also another tip if you want to lower output current is just low power supply voltage of MCU So in that case max reference voltage on inverting pin of opamp will be lower.
By the way Microchip have dedicated enhancement 8-bit micros with analog peripherals for power supply control like high resolution and fast PWM and ramp generator. Just see this AN from them for SEPIC led driver
After taking a peek at the newer AA/14500/16340 driver from Convoy, I think I have identified the SOT-23 LDO regulator in there and here. Marking in this (XHP35) driver's 3-pin SOT-23 is V1SE. Found it is a MicrOne ME6209A-33 regulator, check here (datasheet). Up to 18V of input, this means there's no need to replace it for 2S battery operation.
Nice find :+1:
From real photo from listed product here for 3.3V LDO LCSC and I also search over and find there are variants of that marking V1JE,V1SF, V1SE, V1QH. Seems the first two characters are voltage code and last two are code for year and month of production maybe.
If you remove R9 from schematic you will remove any control from MCU also you need to EN pin to positive terminal. But in that case you will lose any current control of circuit. It will work as ordinary DC DC power supply with fixed output voltage. Another better option is to recalculate the voltage divider which come from output of MCU to input of opamp.
Yes it is, hope it still is as good as it was in this review.
I recently made a comment about it here, comparing it with the not very sensical GT-FC40 driver; and now when I open the GT-FC40 driver store link I get a āSorry, this item is no longer available!ā message. Curious.
What an awesome thread. Thanks for doing this agnelucio!
I would like to use this driver in a 3s configuration. Iām wondering what would be the result if I just hook the driver up as is with the factory 4s config? Is it necessary to change the R16 resistor for this? If so I could use a little help on the math. Iāve read your post about how you calculated the values twice now and I still donāt grasp it. I would also like to adjust the drive current down to about 1900-2000ma (by changing the value of R10 if I understand correctly). At 2000ma my VF would be 11.9v.
Rtop=RbotĆ(Vfavg-VFB)VFB = 47Ć(9-1)/1=376k
360k will do
NewRsense = RsenseĆI/Inew = 30x2.3/2 = 34.5mR
36mR is a common value and will give you RsenseĆI/newRsense = 1.92A
Edit : nearly 4V at 2A ? Are those UV LEDs ? The default value (set for 11Vavg) will probably work. ānot workingā means min mode higher than it should be. A too low value means lower current than it should be on the highest mode.
So going by the circuit, the U4 MP3431 directly drives the LED?
Say someone stupidly shorts the LED outputs together , then itās likely that U4, the MP3431, has been destroyed? I canāt find anything in the data sheet mentioning over current / short circuit protection on Vout. (Or perhaps Q1 could go before U4?)?
