Given how modular the S2+ is - add the charging port/circuitry to the head, so it’s a tickbox and separate option? I don’t know how customisable AliExpress’s storefront is:
I agree that upgradability of the current lights is quite bad for no good reason. I’d love to have a nice lego set that I could build lights from. Different heads, different tubes, different tailcaps.
S2+ is actually quite close to that:
there are different tube lengths available
swapping optics is easy and selection is good
lighted switches, magnets, GITD o-rings….probably other extras are easy to get as well
Could use some larger thrower head or a Carclo triple head.
Though I’m not a fan of tail clickies which makes all these options quite poor to me…
I wish modern drivers supported both clicky switch UIs and e-switch UIs. Want e-swtich only? Get e-switch head and a flat tail. Want e-switch with clicky lockout? Yeah, you know what to do, e-switch head and clicky tail. What clicky only? If a specialized head is not available you could just never touch the e-switch and click-out whatever you like.
For some reason whoever designed these drivers decided to set a layer of solder mask there in the middle of the spring (WHY?). As a modder I super very often do inner spring bypasses and this of course is not a good thing here. So, before I start messing with solder mask removal, may Simon or someone else confirm if there is copper down there in the entire surface? I am seeing a weird cross figure there so I thought I'd better first ask this question.
Looks like the four bits outside the cross would be traces - have you got an engraver? If so, grind a small bit back and do a continuity test between that and the spring pad
Holy Monster…
It would be handy to have an L6-M3-S11 beamshot comparison. Especially, because the M3 looks like the same horror (for anyone who looks into its light ) as the L6 (LED, max current), but in a smaller body.
“The flashlight has temperature protection function, if the flashlight is overheated, the drive will reduce the output current.”
This is what I like the best. Switch on any mode you like, but if the light is too hot, it will dim, so it won’t fry. Small lamps should include this too.
It would be nice if at some point these drivers have have the option to cycle in reverse direction (press for ff>l>m>h) either by double click or by TK style long press.
