【convoy】
If you need a 17mm B35AM driver, I can produce a 17mm 6V 2.2A dedicated driver.
It is more dangerous to use a 4A drive.
yes, thread is suitable ,but the S3 is a little blunish ,the S2+ 18350 tube is a little greenish
I don’t know why XHP50.3 XHP70.3 has been on the market for so long, but we can only buy white light.
no ,Affected by voltage and internal resistance, as well as temperature control, the current actually drops very quickly.
About one month ,and new version has spring.
Thickness 15-25 microns, hardness about HV400
I’d be interested in lights with 90 cri versions, if available.
Those look like numbers for type III hard anodizing instead of the MAO. Is that correct? I guess the thickness can vary but looks like the standard is from 25 up to 150. HV seems to be 600 on the low end up to around 1400.
When I need try different Tir lenses I prefer have host with unscrewable head and integrated shelf similar T2 design.
(I would like if the mcpcb where even more raised to facilitate Led slicing)
The advantages are quick easy Tir Lens change, Led access and more space for larger drivers
than host pill based like S2+ where are necessary more operations and time.
Simon there will be a T2 style light 18650/350 compatible with threads and TIR lens used on S2+?
I don’t consider S3 for their recessed Led inside the head,a bit difficult for modding
Sorry, don’t understand this point. So, currently, Aliexpress has only 12FET+… options available. You say you’re not gonna sell 12FET, so, what does this option actually means then? 8A FET? 8A CC?
I believe another user was asking to buy the parts separately instead of the whole complete light
Awesome, I’m not really so worried about matching colors, I can actually just use a different color for the 18350 tube.
i mean ,i can install 12A fet driver in flashlights ,but i am not allowed to sell the driver seperately
Yes Please!!!
Is 8A buck and 12A linear? So 8A more efficiency?
Lot of people would be interesting in this. :smiley:
Is it possible to use the same 17mm driver but adapt it for 3V and 12V as well?
Simon, have the L6 and L7 models been discontinued? I opened the L Series section of your store and only saw the L8 today.
yes, 8A drive efficiency above 90%
12V ? 17mm 12V for XHP35?
pls check if you visit following links
L6
L7
