It's an aluminum pill nickel and copper plated in an electrolyte bath as described in earlier posts. Hmm, I should reorganize that post since it makes it read like the pictures are of a penny.
The result in post 14 may have been due to a poor plate. I'll try again. Sticking with nickel plating is acceptable for the pill if it solders well. Unlike aluminum or copper, it has the advantage of not oxidizing. I still want to figure out how to get complete copper plating so that I can plate exterior parts for purely aesthetic purposes.
I read something about how brass plating won't work because it's an alloy, but if one wanted brass, it might be possible to plate both metals individually, and then turn them into brass with a blow torch.
Edit: That may be wrong. This says brass can be electroplated.
I don’t know whether Nickel can be soldered to. It seems that there must be some good reason that in PCB manufacturing ENIG is used instead of just “electrodeless nickel” by itself.
I found a thread started by dsche in CPF about copper plating: http://www.candlepowerforums.com/vb/showthread.php?361384-One-easy-way-to-copper-plating-aluminum
So, guys, as part of a personal project, I’ve gotten interested in electroplating.
I’ve tried a nickel acetate solution using nickel strips, and then tried to plate some copper, which worked well.
However, when trying the same methodology with trying to produce copper acetate, there is some metallic copper forming over the cathode side, which infects the solution and produces corroded metallic copper plating, which has abysmal retention and electrical conductivity.
So, what are ways to prevent this phenomenon from occurring?
I’ve found:
1. Reducing current.
2. Getting more material/more surface area.
3. Upping the distance between electrodes.
I saw on youtube a guy doing electroplating on thruholes to make via’s on PCB’s…he used ink with graphite in it to conduct electricity (then dry)…then put into the electroplating solution, the via’s would have a good solution of copper in them
