I would take 500 over 300 every time.
I don’t think your in danger of damaging the eneloops unless you toss them in a deep fryer, they can take a lot of high amp discharges
How does this compares to the HD defiant 3C? Is the throw good enough?
These calculations are incorrect because you are using open circuit voltage in place of actual terminal voltage. The NiMH batteries are not going to experience much of a voltage drop while the light is running. But there is NO WAY that alkaline C batteries are going to produce much better than 1.0-1.1 volts with a 2.2 amp draw. The fact that NiMH batteries can hold voltage MUCH better under a load is the reason why they are able to push so much more current through this (probably unregulated) light in the first place.
Personally, I would just spring for some Tenergy Centura C cells for these lights. These are some of the beat around. And you will get MUCH longer runtime with them vs alkalines without that annoying dimming that you get as you use alkaline batteries. Yes, the light will probably run warmer than with alkalines. But I can say that I’ve NEVER had a light give me problems because I’ve used NiMH rather than alkaline batteries.
What are the switching mode on this flashlight? Any memory mode?
Someone asked in a Private message about the tint. Mine look slightly warm.
Being cheap & mass-produced, it wouldn’t surprise me if there was some variation in tints out there.
I am just wondering why this light does not get more attention from the BLF members. It seems to be the cheapest 3xAA light that outputs 300+ lumen. It has a decent build quality, versatile flood to throw zoom mechanism, long run time with C size batteries, decent run time with eneloop, good heat sinking and locally available with Costco warranty.
Compared to this 4xAAA light New XM-L Light,, 26650/18650/4xAAA Good Price and 57mm head ......... NOTE: The star is solid aluminium !!! :bigsmile: that I bought for 15 from ebay, the Costco ones beats it hands down. It’s brighter, throws farther, floods wider, runs longer on 3xAA. I am just a newbie so I may miss something here. What’s wrong with this light?
What is the price for these? $12.50 for 2???
Nothing wrong with the light.
Should get more attention in USA but I think the BLF don’t like zooms.
Also, for attention on BLF cheap lights first need recommendation by 1000+ posters.
They missed this one so evryone ignores. I think SAD
You may be right. They probably missed on this one. I guess I am not a real flashaholic. IMHO zoomies are more versatile. Most of them don’t have a big head so they can be easily carried in a jacket pocket. I only paid 25+tax for a pair of mine. 1000 lumen for 25 bucks is hard to beat. And if you connect both of them using the lanyard, they will transform into a formidable nunchaku
Did a home made adapter shown in one of the thread here. The tail cap measurement went up from 1.5A to 2.5A and significantly brighter! Nice flooder for the price.
Can’t find the right PVC pipe so I used the standard 3/4” PVC pipe from HD and grind it to fit.
I’m on vacation and saw these in the oahu Costco, tempted to pick up a set. I’ll probably never see these in Canada.
They’d fit better in the luggage than the Defiant light and it was 2 for $30 I think
