The 35.2 does not seem to offer much improvement over the current version. Therefore I dont think there is much interest in it.
I haven’t heard of it being available, so maybe when it does come out we will find some type of improvement. Maybe it will handle higher amperage for increased output? Who knows.
A new 3v version of the 50.2 recently came out. Maybe the 35.2 will be available in voltages other than 12v?
XHP70.2 is throwier than XHP70 because the dies are closer together.
That’s not the case with XHP35.2. It’s a floodier but more efficient variant.
XHP35.2 HI? I don’t think it exists and I don’t think it ever will. Just like there’s not XP-L2 HI.
XHP35.2 might be interesting for some small flooders - but for throwers? I don’t think so.
I don’t think this is true. The big difference you see is that the xhp70 has a darker hot spot center, while the 70.2 has a smoother spread of light. Check these pics at the same distance, same light, but different leds. This is with the exposure turned down to highlight the hot spot smoothness.
The actual throw distance doesn’t change much, but of course the 70.2 is capable of outputting more lumens which can increase the throw a little.
The closeness of the dies doesn’t seem to have any effect on the throw distance.
Since it looks like the 35.2 has the dies a little further apart, we might see a little more of a dark spot in the center of the beam. We will have to wait and see if this is the case or not.
According to CREE PCT, the XHP35.2 has lower lumens output than XHP35 of the same bin until you reach 1A current, for some reason. Then, it starts to take a slight lead in output. But the XHP35.2 has a lower Vf than the older XHP35 version, so it will be more efficient. On the low end, the XHP35.2 even has worse lm/w efficiency than the XHP35 up to 250mA, where they have equal efficiency. Above that, the XHP35.2 has better efficiency. So, it’s a mixed bag. The only measurement that stays consistently better is the lower Vf at each level of current usage from the bottom of the chart to the top.
I know NOTHING about street lighting but if the size of the pad matters for swapping LEDs out that would imply the LEDs would be reflowed for light, is that what happens?
I’d be impressed if so.
I’m curious if the emitter in the picture is a prototype/pre production version. The quality/precision of that phosphor and silicone pour really are embarrassing IMO. This is CREE we are taking about here. Really seems they’re losing their pedigree…
I find this wattage/size emitter about ideal for our lights, so if things change and their high CRI options become competitive with respect to beam quality, I’d have a use for these. But my hopes aren’t high, sadly.
