I think they are saying that XP-G3 emitter will out throw classic XP-G2 but only if we leave dome on.
And since 80% of us here do de doming, and expecting better performance with newer types of emitters it seems such performance upgrade will not happen with G3.
Wait until someone confirms kcd numbers in well known hosts. I know I would not be impressed with anything that will throw less than old production XP-G2 S4 2B de domed no matter how nice tint is.
Djozz sliced XP-G3 and did put it in well known and consistent performance aspheric host(B158) and results are really not good.
So when it will be pure clean de dome only 10-20% gain could be achieved(in my experience) and not even that will be enough to dethrone old de domed xpg2s42b
Djozz wrote:
How about dedoming this led that is build quite different than the XP-G2 ? Some first attempts by other BLF-members at hot dedoming or in gas were not promising. My own (limited skills !) first attempt at a sliced dome produced a working led but the throw was disappointing. See here. So for now, the ’king of throw’ is still the ’old type’ XP-G2 S4 2B, which unfortunately is not available anymore. Cree changed production process for XP-G2 emitters! - #221 by djozz
Luminarium has a tendency to form out-of-context passages from other authors into tidy, neat statements saying exactly what he wants to hear the first time he reads them.
Totally kidding, Luminarium! :laughing:
No but honestly, these fully dedomed G3s do something quite odd or even possibly incredible for some people I would imagine. After dedoming, the hotspot becomes about 5800-6000k. Reverse tint shift! It’s such a neat dual tone hotspot that I’ve begun to like it, a lot.
The die has more phosphor at edges, less in the center, like a dip when dedomed. I have macro photos I will post after I get back from the store of what that looks like.
Why would you say that we are saying “with the dome on”, when I’m talking about a domeless LED? Once again you’re modifying what has been stated by others.
A good experiment is not necessarily putting the LED in a host you are particularly fond of and getting one throw measurement from a sliced-dome LED. To be fair, a sliced LED is going to vary person to person, method to method, slice to slice.
A proper experiment would be using any host, with a “control LED” installed at the start. Then, other LEDs would be placed into the same host, directly comparing dedomed XPG2s to dedomed XPG3s. It makes no sense to compare a “sliced” G3 to a completely dedomed XPG2. If you want max-to-max comparison, then they should use the LED in its maximum intensity form (at maximum output power), not guesswork of theoretical gains it could have in other scenarios.
Can you report in this or any other thread throw or lux values of de domed XP-G3 emitter in direct comparison with old XP-G2 S4 2B…? I say old type and that is the key… You can’t compare them with new production G2’s cause although they share same name they ain’t same emitters. Since you are the only person who knows how to de dome it it would be much appreciated in community.
What I know (and probably Djozz you and other guys here) that with “slicing the led method” vs “de dome method” difference can be very little from 5-20% depending on how much silicone did you sliced…
So If Djozz got 200kcd with sliced XP-G3 in well known B158 host (and it really looks like good slice to me):
and he make that test in direct comparison with old type de domed xp-g2 s4 2b that gives 320 kcd that should tell a lot, cause even your properly de domed G3 if we assume that it will have maximum gain of 20% over Djozz sliced one it will still not beat old XP-G2 S4 2B. It will have about 240 kcd in same host with more current sag in dd light. So nicer tint? OK I respect nicer tint but I always choose better performing emitter.
Don’t forgot you claimed that new production process XP-G2 is good and that you can’t spot differences between new and old type? Although imho you are terribly wrong on that and I (and lot of other guys from that thread) have more than one arguments for that(and still waiting for your reply in that thread).
We do not force MEM to reveal his secrets of dedoming, but an actual throw comparison with some real numbers would definitely bring some light into the whole discussion. And since he is obviously the only one who has succesfully dedomed an xp-g3, his input would be appreciated
I just dunked one into a gasoline, wish me luck (Stuff that I use takes 24-36 hrs to do the job and even after that time the dome will not fall off by itself but if I budge it a bit it will leave nice and clean LED die, at least with XM-L2/XP-G2)…
I wasn’t meaning to insinuate asking was wrong, it was just a strange way to posit the request, but again, that’s just my opinion.
It’s obvious that both MEM and djozz have a firm grasp of the behavior of LED’s and the physics involved, so with the limited data points we have at this time its probably a little premature to make sweeping assumptions one way or another. A test of two emitters, both prepped the same way, used in the same host with the same parameters would be really beneficial in determining if the new XP-G3 is going to perform as well as the older XP-G2.
djozz - Excellent work, once again! Love it!! Also, lot of things look'n good for the XP-G3. De-doming is still yet to be determined, but doesn't look promising for us laymen modders.
I did not ask him to reveal de doming secret but to reveal results in XP-G3 vs OLD (not new) XP-G2 S4 2B de domed battle. Is this also a secret? Don’t make me laugh
Djozz already did such test(only with sliced XP-G3) with B158 host and he got about 50% lower performance than with de domed old type xp-g2 s4 2b.
Well known variables are that de domed vs sliced emitter should have maximum 20% better performance over sliced so properly de domed G3 will still not be able to reach OLD xp-g2 s4 2b. He could reach and have better performance than new production s4 2b but it will never reach old S4 2B. Learn difference between new and old production process xp-g2-s4 2b emitters(Gaston01, other guys and myself learned that on a hard way).
Real variables would be :
- de domed g3 v de domed OLD production type XP-G2 S4 2B(cause that emitter was king of throw until Cree messed it with new production process XP-G2 S4 2B)
- same host
- same driver
- same battery
same lux meter(and it does not have to be super accurate to tell % difference between them)
Djozz did all that with B158 host only with sliced G3 and not de domed one. Add max 20% gain on de domed one and it will still not reach it.
I would really like that G3 or any other new emitter could have same or better throwing potential than old production XP-G2 S4 2B emitter and I am among the first one that would buy larger quantities of it.
I still need to see (or experience) this to believe it… I believe the ‘old’ XP-G2 S4s are still the Throw King, by far.
PS: I’m also worried about the beam profile of the XP-G3s. To me, it does not look promising. And, the other caveat, as we all know, to have this LED properly dedomed, we’ll have to send them to MEM for some ‘special’ attention. Yep MEM, you’re probably smiling while reading this…
I’m just combining some information I gathered from being here for a while, I do not know the exact physics behind it (I’m a biologist, in led physics just a BLF-amateur, i.e. DrJones knows better than me what happens to photons).
*The Cree leds used to have a very smooth phosfor layer and showed a lot of tint shift and gained a lot of illuminance upon dedoming
*I have had Luxeon Q leds, Oslon Square leds, Nichia leds that all have rougher phosfor layers. I dedomed or sliced them all and the illuminance never became anything impressive. The tint shift was also less (qualitative observation).
*The latest XP-G2 and XP-G3 have a rough phosfor layer and thusfar the throw after dedoming them seems less than impressive.
The source of improved illuminance upon dedoming (following DrJones’ explanation from back in 2012) is that after passing the phosfor layer, remaining blue photons that are leaving the phosfor layer at high angles are reflected back into the die and have another chance of being absorbed by the phosfor and then emitted at increased wavelength (and thus luxvalue) and at a perhaps lower angle that will escape the die, thus adding to the illuminance and causing a tint shift away from blue.
What if the outer edge of rougher phosfor without silicon dome, that has less surface area parallel to the die surface than a smooth layer of phosfor (this is entirely my own assumption), shows much less internal reflection in the first place, so even without dome the light at high angle can escape anyway? Then less photons are ‘recycled’ (is this word also patented by Wavien? ), and illuminance and tint shift are less increased. So less throw.
That’s certainly a possibility I suppose. The thickness of the phosphor on the edges could also play a role as well, but that’s only a guess on my part.
Either way, unfortunately, I guess there’s not much we as end users can do about it one way or another.
Thanks again for taking the time to do the testing.
