D1K with new color option and SMO reflector for F150R
Mine arrived today. The good aside from the obvious things: look how long it holds ~300lm on a Vapcell F15.
That’s much better than the Skilhunt M150v4.
The bad: it won’t turn on with the pocket clip installed. I tried pulling the inner tube out a little bit, but haven’t fussed with it otherwise. It won’t work for me as an EDC without the pocket clip.
Edit: after a few more times adjusting the tube and cleaning the contact points, it did come on with the clip installed.
A bit more use after that and it won’t turn on at all with any battery with or without the clip installed. I’m going to email Hank to ask for a place on the waiting list for a replacement.
Edit 2: bypassing the tailcap with a wire from the negative end of the battery to the end of the body tube does not produce any response from the light. I think the driver is dead.
10 Thanks
Mine arrived too, works fine with clip. Button is shit like FW3A/FW1AA, my KR1 works like a charm, just amazing from every side not like this one. Color is like good poop after beans :beans: Tint is shitty pink like usual.
:vs_button: HT35 4500K in S6 on the left
7 Thanks
it certainly looks stunning..
sorry to hear that
I trust Hank will do right by you
suggest you try this:
fwiw
because my V2 was very hard to close far enough for the switch to work, I did these things:
I took the clip off and w no battery inside I closed the cap snugly a couple of times. Then did the same with clip installed, but still w no battery at first.
then I put the battery in, with clip installed.. its getting easier to close far enough to get the switch to work
both my tailswitches work, plain and magnet..
I do still have to try pretty hard to close the tail far enough for the switch to work.
300lm for 150 min is good to see, thanks for the test :wink:
alert:
the thermal calibration on my KR1AA was off by 20C too high
Recommend calibrating thermal set point.
that’s one thing I wanted to know about the readout calibrations…the thermal one might affect the thermal throttling, but does the Voltage one trigger LVP?
**I only ask because someone on another post claimed that they (the voltage readout vs. LVP) were exclusive from each other…
My V2 KR1AA reads the battery at 3.96V atm, my DMM reads it at 3.97V.. I have not made any adjustment to Voltage calibration. A difference of 0.01 is too small to be within adjustment range. The Voltage adjustment only goes down to 0.05V, so I dont feel any adjustment is needed. Im fine with the light reading 0.01V lower than my DMM.
Thermal calibration is a separate feature than Voltage calibration, they are not linked.
if ThermCal is linked to ThermThrottle,
is VoltCal linked to LVP?
Adjustments to the tube position were the first thing I tried.
It doesn’t even flash when I bpyass the tailcap with a wire, so I’m pretty sure the driver is dead.
sorry, I see you mentioned that already in your post
sad to hear your driver died…
Maybe, maybe not. When I was testing standby drain, I noticed that it often wouldn’t flash at boot time when I bypassed the tailcap. But it would still light up the aux LEDs, and functioned normally with the tailcap on.
I think this is due to the battery measurement it attempts to do at boot time. When I bypass the tailcap, it always detects the power source as “weak” and limits output, and flashes 3 times. It may even be limiting output to the lowest level, which would make the flashing basically invisible.
About the clip vs spacer, I think there is a smaller secondary O-ring which should be there when the clip is installed, but not when the spacer is installed. Not sure if that makes any difference, but it’s a thing to be aware of.
Anyway, I think it might be good if there is a KR1AA V3 which sacrifices tailcap lockout in order to make the power and switch connections more robust. Physical lockout is less important than mechanical reliability, especially when soft lockout is available.
Yes, I’d recommend always doing a factory reset on any new light… and make sure the light is at room temperature first.
Yes, the voltage calibration controls the LVP level too. LVP activates at 2.9 V, but if you change the voltage calibration, you change the internal values it uses for all voltage-related functions, including LVP. So if you intentionally set the voltage calibration 0.2 V high (so a 3.7 V cell would be reported as 3.9V), the same effect would apply to the LVP level. It would activate at what it thinks is “2.9 V”, but in reality it would be 2.7 V.
(edit: I was sleepy and had the last number backward)
I’ve been meaning to maybe make the user’s adjustable voltage calibration more precise, but haven’t bothered yet. Internally, the driver has 0.02V steps, so it can do 3.90 V, 3.92, 3.94, 3.96, 3.98, and 4.00 V … but the user’s calibration options go in 0.05 V steps.
That’s because the readout was originally in 0.1 V steps, so a 0.05 V adjustment was precise enough to make sure it was accurate. However, the measurements and readout later improved to 0.02 V steps, and the user adjustment didn’t change. So it’s a bit coarse now.
I’d like to make the user adjustment more precise too, but it has a downside. The UI for the adjustment would need to change. It currently goes from 1 click to 15 clicks, with 7 clicks being “0” and any amount greater or less than 7 goes in 0.05 V steps. So, 5/6/7/8/9 clicks would be -0.10 V / -0.05 V / 0 V / +0.05 V / +0.10 V. However, with precision increased, it would be like 5X or 10X as many clicks. Or it would need a different way to enter the data. And the difference may be a little confusing for users who are accustomed to the old 0.05 V steps.
So I’ve just left it as-is for now. It’s not as precise as a DMM, but it’s more precise than most battery chargers… so maybe it’s enough?
6 Thanks
Good to know. Aux was enabled (as voltage check, low brightness) last time it was working and the aux LEDs do not turn on when I bypass the tailcap, so I still think it’s dead.
I’m not sure it’s relevant, but if anybody’s trying to dig in to the issue, I was about to test it with an Eneloop when it died. It kept tripping weak battery detection, so I tightened the tailcap quickly and firmly a couple times just before it stopped working.
I share this position. The KR1AA is probably not the flashlight someone stashes for years for emergency use and really needs to have zero standby drain. It’s an EDC light meant for frequent use, and Anduril’s soft lockout is a good design requiring multiple fast clicks (as opposed to bad designs where a very long press unlocks, which can easily happen in storage/transport).
Thanks! I was hoping to trick the LVP, lol…i.e. if it were locked to 2.9V, tricking the calibrator to believe the cell to be at 3.1v when it was actually already at 2.9v, thus allowing it to discharge and purposely misread 2.7V as 2.9V for LVP…
100% agree with you, your Anduril lockout works well and is easy to operate.
As it is the KR1AA isn’t a light I’d want to keep in a bugout bag or emergency kit due to reliability, but if it was I’d probably drop a disc onto the battery to isolate it.
I often get the triple blink on my V1 KR1AA when I change the battery through the head.. its a pretty big source of frustration for me
I would rather not have the triple blink feature, so I could change the battery through the head without triggering weak battery mode.
I almost never get the triple blink when I change the battery through the tailcap. But I prefer to keep the tailcap closed so the clip stays tight.
On my V2, the main frustration is that It is very difficult to close the tailcap far enough to get the switch to work.
I really enjoy using the light, when Im able to close it successfully. But as things are now, I just dread opening the light (both V1 and V2) for any reason.
future wishes:
I would like V3 to be easier to close the tailcap, and or I would like to be able to change the battery through the head end, without causing weak battery detection.
regarding O rings:
Here is a pic that Hank sent me, of the two O rings. fwiw, he told me to remove the lower O ring when using the plain metal ring in place of the clip.
The lower O ring stops the clip from spinning, if I dont use it, the clip spins freely. I like having the clip not spin so Im using both O rings with the clip.
update
On my KR1AA V2 I spent some time working the tailcap loose then tight against the body with no battery, no clip, and no Orings installed. Then cleaned the body and tailcap threads, and reinstalled both O rings. Then relubricated with Nyogel 760g, and reinstalled the clip.
It is getting a little easier to close the tailcap far enough to get the single flash, and for the switch to work. And Im not getting any triple blink low battery detection when changing batteries through the tailcap. Im encouraged by the improvement in being able to close the tailcap without it being such a battle.
There definitely is a bit of randomness here.
I have three KR1AA (two v1 and one v2). None of them have any issues with getting switch connection. None of them ever do the “triple blink” when changing the battery. I change the battery at the head on all three of them (my v2 is unglued).
I really like the o-ring modified v1s. Their switches are perfect. Requiring around 1600g of pressure to activate they can be confidently pocket-carried without lockout with no accidental activations.
I’m not a fan of the v2’s switch. The o-ring mod failed to work on mine and the stock switch requires less than 1/3 the pressure of my o-ring modified v1s. The v2’s switch activates far too easily, making lockout mandatory during pocket-carry. The need to use any method of lockout is a big negative as it makes a light take much longer to deploy.
Personally, I think Hank should do the following:
  • Withdraw the v2 and replace with the v1. The v1 is the superior version of the KR1AA in my opinion. Mechanical lockout simply isn’t necessary in a light of this type and the drawbacks of the v2 outweigh the advantages.
  • Offer the v1 for sale with an optional “higher resistance switch”. All that’s needed is for Hank to install a 9mm x1.5mm o-ring inside the rubber button boot on top of the popper. It’s an extremely simple mod that work’s with the v1’s switch. but not the v2’s switch. A lot of buyers would probably be happy to shell out an extra dollar or two for a premodded version.
  • Redo the clip out of thicker material. The stock clip isn’t strong enough to provide secure retention to a pants pocket. The steel used is too thin. The solution is to manufacturer the same pattern clip out of thicker steel.
You can trick the LVP.
I don’t recommend it, but you can if you want. Give it a bad calibration value, and it’ll activate at the wrong voltage.
On the D3AA / DW3AA / KR1AA driver, it needs to measure the cell strength because otherwise it will try to overdraw a weak battery when you ramp up, and cause an instant reboot. With an average alkaline cell, for example, attempting to go anywhere near full power makes it fail, so it measures the maximum output a cell can handle and sets a limit just below that.
It’s also important while flashing firmware, to make sure it won’t try to draw too much power from a flashing adapter. I learned that one the hard way, turning a chip into smoke on one of my pogo adapters.
Unfortunately, it also means when you tighten the power connection too slowly, it does the measurement when power isn’t fully connected yet, so it correctly detects a weakness in the power source, and limits itself. … and then once it gets tightened, the weakness goes away but the driver doesn’t know that.
I might be able to make it boot slower on this particular light, to give the user more time to tighten the tailcap before it measures. It’s just not an issue which ever came up before.
Yeah, the clip does seem a bit too thin. And the 180 degree deep carry bend seems slightly too narrow. The opening isn’t wide enough to clip onto some of the fabrics I clip other lights on. A denim pants pocket, for example is a little bit too thick to fit. Works fine with KR4 or D4K, but not a KR1AA.
The proportions match the KR4, so it looks right… but everything is scaled down, so the bend is smaller too.
The bend in the clip is a bit small.
However, I can fix that by wedging something inside, like the nail file on a Victorinox mini knife, and opening it up. And I can use pliers to bend the clip a bit so it still has retention.
What I can’t do is fix metal that is too thin.
good idea! :wink:
thanks for the details, that explains why the KR1AA lost all my options settings, as if I had done a factory reset.. during one of the times I was struggling to close the light and got triple blink (I was experimenting with a slightly loosened head, to make it easier to close the tailcap.. my V2 head is not glued.. but I have learned to keep the head tight for fewer problems with triple blink)
Im all for the idea of testing for a weak battery, especially if the false weak battery detects can be reduced..
I can’t really screw the tailcap shut any faster, since I have to change my grip repeatedly to close the tailcap, so there will always be pauses during the tightening process..
a longer interval to test for battery weakness seems like a very good solution…
thanks for all your efforts :wink:
It shouldn’t be losing its config settings. Factory reset only happens when the button is held, and only after the warning animation has played out long enough to finish (about 4 seconds). The battery measurement and 1-3 blinks happen before it even checks the button or attempts to load any configuration.
agree, after a triple blink error, it usually does not lose my options settings.
I ordered my V2 with unglued head. I had the head half unscrewed, because that makes it easier to close the tailcap tight. But it gave a triple flash, and when I tightened the head the switch only produced a very dim output..
after reopening and reclosing the tail, I noticed my standby Aux had gone back to rotating colors, not the Red Aux I had set.
I also noticed the thermal sensor was reading 20C too high, as it did when I first received the light.
This reset (without a visible ramp and flash) has only happened once, during the many times Ive had triple blink from not leaving the head tight all the time
Im trying to restrain myself, to not loosen the head.. thats what causes the most triple blinks
