DC-Fix Diffusion Film ,Amber and Zircon minus green filters
I usually cut a square a smidge bigger than needed, and use the glass lens as a cutting guide.
I’ll pinch the filter onto the glass and use very sharp scissors. Let the edge of the scissors gently glide on the glass edge.
It’s worked well for me for several filter cuts.
I find a coin, a battery or a socket from a socket set and use a black fine point sharpie to make a circle . I then gauge how close I need to cut to the line .
I use a headlamp.
Cut over a white surface.
Do a rough primary cut around the outside of the circle or a square around the circle so there isn’t a bunch of material outside of the cut pushing back against the scissors. I cut them off while making my cut . Part of the trick is to always be making the turn while cutting since cutting just a straight line is what the wants to do .
Make shorter little cuts and turn turn turn .
I use really sharp Fisker scissors .
Find what part of your circle is best and fit it into the bezel to figure out what part of your cut needs trimmed .
Small trimming, trial fitting and when it’s right the filter won’t bow out .. it will just snap up against the lens and you’re done .
If you can get the bezel off or lights that open up then it’s very simple . .
The first light I did have a glass lens over the optic, so it was easy even though my cutting was terrible.
Are you saying that you essentially friction fit the filters even on the outside? I had assumed some sort of adhesive was required. I believe Cheule suggested using a UV cure resin, but that’s more of a permanent solution. I had considered double-sided tape, but that would also introduce some optical distortion (and possibly even add green lol!).
Got 3 main options…
  1. Snap-fit like on my Xeno. Just worked out that way, some irregular corners let’s it snap into the bezel right atop the glass. Left it.
  2. Adhesive. Got a few with that stuck on where I can’t take out the glass. Never got the urge to remove it, but if I did, I’m not sure if the adhesive would leave traces on the glass.
  3. Between glass and reflector. When using non-adhesive DF, it’s the best way. My Tacklife and a bunch of others, have that. Easily reversible as long as it’s accessible from front or back.
Pick which one(s) are appropriate/possible.
As long as there is tension between 3 spots of the circle against the inside of the bezel it will keep the filter in place . This is because the zircon filters have that stiffness. So I fit the best part of your cut into the space and figure out where I need to trim and the try it , trim some more , try it. , trim and it will stop flexing outward and just pop into place .
Lastly remember not to clean your filter with strong cleaning sprays like 409 ,you will mess up your filter . Use water and a soft cloth .
Thanks everyone - I am glad I asked!
I think the stiffness of the zircon makes it harder to naturally make the left hand turn when cutting because the part you’re cutting away is pushing against the cut . I try to remind myself when cutting to continually make the turn .
I’m thinking that the easy solution is to make a rough preliminary cut just outside the circle you just drew , to make what you’re cutting away just a thin tail of material with less ridgidity to push back at you while you’re cutting . Obviously you can simply snip the unwanted piece away as you cut.
Did you try tapping the punch firmly with a hammer over a semisoft surface? I used the back of an old mouse pad for some give and was able to cut clean circles with the punches. I’ve also succeeded with using a scrap of pine instead of the mouse pad. If the punch can go through leather, it should be able to cut through these sheets.
Try spray on poster glue. When allowed to dry on the film first, then applied, it’s a non-permanent adhesive. Applying while wet is more permanent.
I’ll have to check my punched stock to see. It’s been a while. How many microns thick is the thicker zircon stock?
well it took a little over a year, but info sent :sweat_smile:
I used DC Fix on my new Baja Designs LP9 Pro “”“Headlight”“” and it’s an amazing difference for recording video with fullframe chest mounted camera.
I ended up using ‘d-c-fix 346-8093’ which I think isn’t what everyone else is using? It’s a pretty light diffusion.
Right now I’m looking for something a little stronger diffusing for use with a Mule NOVMu V2S, about 1.5" distance in front of the emitters not to soften the beam as it’s already flat, but to soften the shadows. Trying to balance distance from emitters (so overall diameter of diffuser) and minimizing loss of light. The ‘d-c-fix 346-8093’ I’m using wastes very little light but it’s diffusion is a bit too weak so it needs to be spaced about 3" away from emitters to soften shadows adequately…
Thanks for any input!
