I'm thinking the FT ones and this one are at the same level of quality. Think the stock one I got came from is the name brand/model as the FT one, but comes from another source. Main issues with any of these cheap lights:
check if there's a driver spring - if not, then needs a button top cell, or at least some sort of clearance for the cell to make contact. This is more common in cheap lights to have no spring.
sometimes the press fit drivers don't have a good ground connection (I just found this in a cheap zoomie from GearBest). You can easily check for this by on the bench by removing the pill, check continuity from the ground ring of the driver to the pill. Could try it with a battery as well and a wire - put the cell in the normal position against the driver, one end of the wire to the cell neg. end, other end of wire to either the pill or driver neg. ring. To fix it, sometimes I use a metal chisel and hammer a notch in the pill edge and driver. The little wedge you make will drive some alum from the pill into the ground ring of the driver. Do this in 2 or 3 spots equally spaced.
check if the problem is the tailcap by removing the tailcap and use a screwdriver or jumper wire to ground the cell neg. end to the housing
Yes it only runs on button tops, and no its not the tail cap either. Really, in such a cheap light it works, or it doesn’t, and if it doesn’t, its most definitely “not as advertised”.
I didn’t really expect much for a $3.50 light either, just a working light with a relatively usable output that didn’t color the wall blue It is very blue compared to the Fasttech beamshots, and the beam has multiple levels of rings, compared to those shots it seems significantly worse. Rings wouldn’t even have been much of problem if they worked and weren’t so blue and dim. As it is, I can’t really feel good handing it to acquaintances of a friend who forgot their lights “here, use this junky barely working thing that you can probably not see as good with as the reflection of light from my light’s beam.”
I’ll look into modding what I have left like you did probably though, after I get my partial refund. I have a few XM-Ls, and it seems a newbie modder like me could probably just put them in and get reasonable upgrade of non-blue light out of it?
Oh and PS, for the $5.80 something or whatever at Fasttech, even if these things worked better, this is a very poor buy compared to the Ultrafire 878 that you can get for $6.99-9.99 Review. Aura Buy UltraFire W-878 Zoomy.
The 878 has a real XML, light output is good, the beam is not blue on any that I had, it can use 26650/18650/3xAAA, it has 3 output levels instead of 2, the body is massive so if you wanted to mod, its heat sinking capacity is great! This is what I had for “handing to someone” lights previously, but one person liked it so much they ended up keeping it, and one was lost. I think I’ll spend the extra $$ next time, $3.50 was too tempting though
So, BTW, for those who got the one I got from Ebay, how do you get the pill out? Do you have to drill your own holes in the front edge of the pill (from my pics above, there are none there) and then use tweezers?
+1 B42. What I did was get some decent cheap emitters like these XP-G2s from FT - qty 5 for $2.23 each. Just put one of these in the cheap GearBest zoomie (linked above) and came out real nice! I got plenty of SinkPAD 16's, so I did use that, sanded down to about 14mm to fit, sanded it down to be thinner (about 1.24 mm from 1.55mm) but still you could simply replace the whole stock LED/star for a few more cents buy it pre-mounted for the size you need. For under $3 it's a real nice mod upgrade: better tint, more output, still has decent throw. In my zoomie, looks like all the blue is gone, just more of a pure white. In zoomed In (throw), the emitter pattern is smaller than a XM-L2 and bigger than the stock XPE.
I got cheap zoomes with XM-L2's, XP-E2's, and XP-G2's and I'm thinking the XP-G2 is the best trade-off of brightness and throw.
Tks Tom, but I think (unless there is some other reason for not putting an XML in?) the XML should output more total lumens, which is what a new user would like anyways in hiking.
That is pretty much what I do with mine, although I go with an XP-G2 because it gets rid of any rings. The original ones I had gotten where XPG and that was one of the reasons I recommended them. But I still think for next to nothing they are great lights. Maybe this will get a few guys into modding their lights.
As for the guys who got bad ones, I would file a claim too. Cheap is one thing, not working is another. I’m sure if you bug them enough they will offer most of your money back and then you have some cheap hosts. For the record I bought three and they were all working.
For the record, I’m not blaming you, I’m frustrated most by the percentage of working lights I got. That its a dim blue XPE and not an XPG adds insult to injury and makes it not worth it to me for free as is.
But, the fact I’ve got some XMLs to practice putting in and they wont want a bad rating for $7 and are likely to refund probably makes it worth it in the end.
I’d still not recommend anyone buy these over the Ultrafire 878 though, just absolutely no contest on any front except if weight/size is the most important to you, and for only $3.50 more getting an XML, non blue and bright emitter, good quality and weight host with smooth zoom, 26650/18650/3xAAA is worth it.
Without a doubt you are having a problem with either the driver not making constant contact or your batteries are not making contact. Someplace the power is being cut off to the driver. It’s probably what is wrong with your broken one’s as well. Do you have any of the longer protected batteries? If you do give them a try and see what happens. I would also try taking the driver out and putting it back in place firmly. Heck use a hammer if you need to. Something to make that driver really stuck in place.
And just like everyone elses, they are crap, they make light but it’s got a really bad tint and ringy and just feels “cheap”
Just letting the kids have em…worthless for modding as the aluminum body isn’t even got enough heft to absorb any heat. Sure I could mod it, throw in a XM-L/L2 and put in a better driver but that would cost me MORE than the entire light itself…and then you couldn’t drive it over 2100mA w/o it getting way too hot too fast
edit these are “ok” for GP use and for ultra cheap 18650 flashlights…there are better, but these are ULTRA BUDGET
The fact that it is thin can also be a virtue - it has very tiny footprint. And heatsinking is enough for the current it’s driven at. Feel free to disagree. For me, I put mine (bought before this) a spare laptop pull 18650, stash it in a toolbox - then forget about it. It barely take any space but always there when you need it.
If a friend decide to “borrow” it, I don’t really lose much.
One free mod is to dip your emitter. If you don’t like your tint then there’s nothing to lose. Mine came up more neutral after dedome and much nicer beam.
I am having good luck with de domed xpe's . The tints improve and the emitter projected is about 2/3rds the size before de doming ..How many amps are these pulling stock ?
The one I modded has excellent heat sinking - the heat gets to the outside really fast . Ok, there's no where else for it to go but out. SK-68's are way too bulky for my use. I prefer the thin AA zoomie's for modding you can still get cheap, under $4, here for example.
I just like the idea of a very thin, lite carry light that can do some serious throw'n, and still have some runtime with a 18650. It's the smallest 18650 zoomie around in terms of width.
Being a low $ light - these came with variety of stock amps depending on your assembler and how stressed or pissed off he/she was during assembly. Based on past BLF readings and mine I believe they can be between 0.6A and 1.2A stock.
Fixing the wires/spring normally will remedy it to the 1 - 1.2A which I think is what it’s designed to be. Bypassing the driver resistor pushes it to 1.5A - 1.8A but not much gain in lumens, some, but not worth it IMO. Better off with around 1.2A, maintainable heat and longer runtime.
