I also noticed that. They did not always make good contact with the terminal in my C9000 charger.
My local Walgreens had them for $8.99 I don't know if they do now. I don't think they are Eneloops.
I tested them in a high drain (6amps) light against the original eneloops. These things dropped voltage like a rock real fast, as in a couple minutes, where my original eneloops held much longer, as in ten minutes. I do not believe they are eneloops rebranded.
They looked fine in my testing a year ago. Were yours “Made in Japan”? The older Duracell “precharged” cells could either be duraloops or something else that was “Made in China”.
Yes, the same packaging and wrappers and made in japan on the package. They just did not perform like eneloops. They dropped to 1V quick as can be and the eneloops just dropped slowly like they always do. If they are new eneloops, I don't want them. I will keep them for low drain stuff in the house, but I won't use them for flashlights. I have 2 packs of them and they both behave the same way.
Huh, thanks. I just went back and checked what I said about the old ones, they sure seemed fine: tested a single Duraloop-XX @ 5A
Do you have an opportunity to do a 5A discharge? (I assume not or you would have already.) If you could do that it would give results which could be compared (at least a little) to both my results and HKJ’s results.
Regardless, it sounds like something to watch out for.
EDIT: Rather than testing @ 5A or whatever you could just mention how long the cell took to drop below 1v. HKJ’s charts show that the Eneloop XX I decided my Duracell Ion Core was equivalent to could maintain >1.0v for ~25min at 5A and 18-19min at 7A. Stands to reason that you should see around 23min of >1.0v. I guess that’s not what you got though!
Am I correct in recalling that the Eneloop XX doesn’t maintain it’s voltage under load quite as well as regular Eneloops, or am I confusing it with something else? I’ll try to find my logs and post some numbers when I get the chance.
It’s an extremely slight difference. Regular does better at the most extreme currents, but not enough to matter IMO. XX does better at lesser currents, not enough to matter.
The Duracell online deal is back on, buy first pack at $8.99, buy 2nd pack for $8.99 - 40% off. Pickup in-store.
Both stores close to me are out of stock. Hope they get some in soon.
Toys-R-Us 40% off 2nd pack deal is ON! (order online, pickup in store)
Ok this year i walked in during a huge rain shower so they really didn't have any business and i noticed a big crowd around the customer service desk.one of them was clearly a manager (assistant) .When I brought them up to the register I said there is a buy one and the second one is 40% off . She rang them up and said ..20.68$..To which i said "i think it's supposed to be like $14.28"......to which she said ..NO " it's 12.99 and the second one is ...."..
Just to prove me wrong she got online and said ..."OH ..my bad " it's 8.99 and 40% off of 8.99 is ..
So this time I scored a couple packs just to try the newer duraloops ...
not a great deal .. not a bad deal.. /
new loops makes everyone happy :)
