decent amp tester
here’s the thread
I had because I’ve been thinking about buying a multimeter myself.
I think I’ve finally settle on buying a clamp meter and cottonpickers meter for lower amp readings.
My Elenco with thick gauge leads gives me results I trust. Like showing 1.4A from a light I put a 1.4A current regulated Nangj driver in. I also got the exact same current measurements as Foy in my E1320 modded UF2100 (Nangj driver at 3.5A -E1320 5 modes).
-Garry
Oldaker makes some very nice leads (in the USA) that sell for a reasonable price.
Harbor Freight has coupons for a free DMM w/ any purchase. That’s the only way I’d get one. If you get 5 new ones from them, you’ll get 5 measurements.
Clamp meters are great, but nothing cheap will do DC well, only AC current. I have a Craftsman 82369 and I love it, but would not trust it to be accurate beyond ± 50 to 100ma. Something with decent DC clamp accuracy is going to be more like $200 or more.
When you are hooking up leads anyway I don’t see the point in using a clamp which will NEVER be as accurate as a serial wired meter.
Oldaker look like some nice leads, found a set on ebay for $25, PL 518-6. They have shrouded banana connections required on newer meters, but my $5 Chinese leads have worked fine so far.
Even high end dmm got diferent reading.I got 2 fluke a 79 series 2 also 88V and they dont Read the same.
Current measurements even from very good meters are less reliable than voltage or resistance measurements.
Use railway track as your conductors and keep the leads short and the results will be a bit more reliable.
Reliable current measurement is hard.
Railway track would have a lot of resistance, wire may work better. :P
If you decide to use railway track, look both ways first.
At least on the HF I use, the difference is ~10% (1.9A to 2.1A on my DD test sample) to significantly more expensive RMS meter, each with their own leads (consistent with fluke leads across all the better meters), most of it down to the crappy leads on the HF. There’s just a much of a difference depending on just how much pressure I push on the leads against the tail-threads and cell, ~1.9 if only apply moderate instead of hard pressure.
Ironically the highest reading is from the HF with the “best” leads off a mediocre meter (Metex ME11), ~2.2A.
I suppose it’s possible HF sources from different places, but the two of them I have which came with different looking leads do perform the same.
Also, this is only for simpler resistive circuits, aka DD in our case. A current/power controlled driver (which controls its innards based on feedback) is going to do its job no matter the meter, which is rather the point.
The LED analyzer that I am developing (Any interest in a LED/Battery analyzer device?) uses Hall effect current sensors to measure current. The ACS758 high-capacity (50 amps and over) sensors have a 120 micro-ohm burden resistance… that’s in the railroad track range. The lower capacity ones (5-30 amps) have a 1.2 milliohm resistance.
You could build up a little gizmo with one of the sensors, a 9 volt battery, and a 5 volt regulator. The output of the sensor is a voltage that is proportional to the current flowing through it. You would measure that voltage, subtract the zero current offset value, and multiply the reading by the sensor’s amps per volt factor to get the current. There are several sellers on Ebay that sell the sensors mounted on a circuit board for a few dollars.
Or buy one of the LED analyzers when they are available… it has two current sensors (for battery current and LED current) and it does all the signal processing and boring math. With the 20 amp sensors, the reading noise/resolution is in the 1-2 milliamp range.
