I’m running it in a ZY-T08 and I’m getting around 3,000 lumens at startup and 2,800 steady after that with unprotected sanyo’s. This will pop the protection on Panasonic 3400’s after about 30 seconds. It’s more lumens on startup with samsung 20r’s but I don’t remember exactly how much.
I couldn’t tell you how many amps but you might be able to guess considering that it pops the protection on two pretty good cells. I think it was comfy who ran this same driver to power a 3xMT-G2 and he was getting about 3amps per emitter with three cells.
I e-mailed both wallbuys and fast tech to see if they would put this driver in stock. They both said they would but neither of them have and it was a while back. It can be trimmed down some to fit the XY-T08 but not much if any more than that. 29mm
I have also used the original 3xT6 and the driver from a J-18 and both worked well and can be modded to put out more if you wanted to. I have a link someplace that sells them. I’ll try and find it. It’s in Spanish I believe.
Fasttech sells a 3xT6 copy, it was what I original tried at the beginning of this thread along with the pot mod. Maybe I’am trying to reach too high on that mountain. I’ll keep looking and testing. Maybe I can find a happy medium some where.
Thanks for the info 18sixfifty.
You’re welcome and let me know if you have any luck. I really want to put together a 3x again. I did it once with the IO in fact I tried three different IO drivers and they all had the same thing happen they froze up. Apparently they do the same even if running one.
I couldn’t find the link for the J-18 driver but the number on it is TR-0169D
I knew Taskled would be tried at some point. I doubt you ever will have a problem either. I know that’s is about as good as it gets besides maybe cpf member Der Wichtel’s driver original for the SST-90. I’am not really looking to spend that much on the driver alone. I would like to find a budget driver to get the job done. I appreciate your response, Taskled drivers are some of the best made.
I’ve had two of these drivers for a couple of weeks but not game to try them as I will probably blow them up. I’ve cried enough this year. Its bad enough blowing a $20.00 led up.
MRsDNF, by all means blow ’em up! But please get it on film!
I saw this light and thought it would make a useful host for an MTG2 I plan on running at 5 amps. Willbuying 2x18650 XML light Anyone play with one of these yet?
I believe all the lights you linked to are parallel except the JM26 which only has one battery not two in series. The batteries would have to be in series to run an MTG-2 because of the 6 volt requirement of the led.
MRsDNF wrote: I believe all the lights you linked to are parallel except the JM26 which only has one battery not two in series. The batteries would have to be in series to run an MTG-2 because of the 6 volt requirement of the led.
That’s correct. It would be a PITA to switch the around and the Shadow JM26 does not offer an extension tube as well as it is too expensive. Those are just the form factors I would like to play with. I was not sure if someone had found a variation similar to those lights as there are often many copies and copies of copies that maybe a cost effective variation was out there that could take the heat and provide the power after some re-wiring and souping up. I just don’t think clearly or express myself well so late after my bed time. I am intrigued by the MTG2 and read as many threads as I can about others experiments to learn as much as I can. I have a knowledge deficit regarding this type of electrical and thermal challenge as well as circuitry/ programming are so far outside my understanding that I just call it black magic.
After playing for a while with the 'too small' Shadow tc300 with the MT-G2 over 5A, I'm not that concerned about the heat anymore. The led keeps working fine with the shell being too hot to touch, and it takes a long time for the batteries to heat up that much. In the open, with some air movement, even the body does not heat up that much. So as long as the led seems to cope well with the heat, the large heat difference between shell and surrounding air makes for relatively large heat dissipation for the small surface area of this host.
The small sun ZY-T08 is a great host for a MT-G2 you just have to take it apart and mod the battery carrier to series. It’s easy. I have done four of them already and have two more on the way from Wallbuys.
djozz, that might work in Amsterdam, but in Central Texas we have summer nights that stay 100º and better til way after midnight. It can be near 90º at 3 AM. So the ambient air doesn’t do a lot towards taking heat off a light. With dark-thirty temps in the 106º range a lot of the time, around here we just have to consider toning it down.
2 years ago we had over 100 consecutive 100º days, no break at all. Think about that, over 3 months where every stinking day is 100º or more, with many of those 112º or so. Get’s old.
So your saying, DBCstm that your hands are already acclimated? That’s the benefit of the California valley, fresh fruit, wine, women, a cool night breeze from the delta and all the taxes and legal constraints a person can tolerate.
